Priamry Oil Level
RE: Priamry Oil Level
I not sure if anything has changed from 96 to 03, but on my 1200 set the bike level, remove the clutch inspection cover (derby cover). The oil level should even with the bottom of clutch diaphragm spring. There is a rib on the inside of the primary at this level. Make sure you have the proper level as this is also your tranny oil. When purchasing material, pick up an extra quad ring, they have been known to leak after a few removals etc.
I've changed mine twice. After draining, I dump 1 quart in, through the inspection hole, with a little funnel made from a piece of an oil bottle. Had no problems. Book says it holds 1 quart, that's what I put in. No messing with derby cover, etc. etc. I'm running Valvoline straight 50W in mine.
I looked at mine tonight and it is well below the derpy cover, I will probably drain it all and just start over. I shined a light in their and could see it at the bottom of the clutch. I noticed it was starting to whine when I ran it for a while, so that is probably my problem.
09BlueRoadKing
05-31-2010 06:47 AM
