Rush Slipons
Can you explain in a little more details on running rough??? I installed rush slipons with 2" baffles and the only issue i had was a little popping on decel. other than that my bike ran fine. your bike could be running really lean. what does the plugs look like? You might have to add a fuel management system as well. Are you still running the stock Aircleaner? try and give use more details so we can help you with your issue.
your feeling sluggish when you give it throttle off idle? does it run better in higher rpms? this is called "lost backpressure". You lost torque by installing the more open pipes. And your rough idle is because now the air/fuel mixture is now a little leaner. To tune you need to get some type of aftermarket fuel controller like a PC5 or fuelpak or supertuner. And if its popping on decel its because its running lean. your can run it like this if you want but you could have problems later down the road with running to lean for extended periods of time...
I have a '03 sportster 1200 i just got a couple of months ago. I got the Rush Slip Ons and i put a K & N high flow tear drop air filter on it, since my buddy had it laying around from his 2003. I had to have it re-mapped also because i was getting the popping on decel and it would pop sometimes when i was at lower rpm's or starting off from a stop. Took it to my buddies shop and he put it on the dyno and did the work. Runs like a champ now.
