2004 Main jet size ?
Old 07-01-2006, 02:42 AM
70mach1's Avatar
70mach1
70mach1 is offline
Default 2004 Main jet size ?
I no I should have a manual , and yes I will be getting one soon .
Should I buy the Harley original or the aftermarket brand ? (2004 Sportster 883 XL )
Now for my main question . What size Main jet is standard from the factory set up ?
I replaced my exhaust with Vance & Hines sss and added a Arlen Ness big sucker stage II AC .
Directions say to install a 175 main jet , and 45 idle jet .
I changed the idle jet from a 42 to a 45 but to my surprize the Main jet was already a 175 .
Is it standard factory installed ?
I was thinking of going to a 180 .
Seams to run good like it is and I havent noticed any difference in plug color .
Thanks for any info .....
2004 SPORTSTER 883 XL
VANCE & HINES SHORT SHOT STAGGERED
ARLEN NESS BIG SUCKER AC II
PLUS , EXTRAS ........
Old 07-01-2006, 07:31 AM
AZFlyingDiver's Avatar
AZFlyingDiver
AZFlyingDiver is offline
Default RE: 2004 Main jet size ?
175 main jet is stock and should be fine for your setup...
45 pilot jet sounds right too...
Just make sure your idle mixture screw is adjusted (usually 2 1/2 turns out or so)...
If it's running good and plugs look good, I'd say you're good to go, though!
Oh, and:
Of what? The manual? I'd definitely recommend the MoCo's manual if I had to have just one.
Harleycamper53
10-14-2017 07:34 AM
Rockrspud
03-07-2010 03:57 AM
70mach1
Exhaust System Topics
07-01-2006 02:43 AM
70mach1
06-29-2006 01:48 AM
Sincecrazy
08-27-2005 12:18 PM
Quick Reply: 2004 Main jet size ?
