life expectancy
There is less to go wrong with a carb also.
All they do is get dirty, while fuel injected bikes have fuel pumps, oxy sensors and lots of other stuff to run amuck.
Nothing wrong with a good carb, and yes, make a change and buy a $20.00 jet instead of a $300.00 tuner, then dyno time.....
Brett
Brett
Midpegs (11-19-2019)
at what milage should you start getting concerned about on the 1200 and 883's?
i understand that each owner rides differently and does different maint. but just looking for a general idea. its looking like i can afford about $6k in a bike right now and im coming up with about 9,000 as average miles for that price range for a bike 2006 or newer, is that something to be worried about?
Brett
Brett
I have a car from 1976 with EFI. The system is largely analogue electronics and there are numerous kludgy-looking vacuum diaphragms to monitor manifold pressure. The EFI circuit board is rudimentary at best and the capacitors are nearly 35 years old; well past their design lifespan. The system is ridiculously crude and any one of a few dozen vacuum leaks can throw it out of whack.
Here's the starting procedure for that car with it's 100% original EFI system from 1976: Turn the key.
That's it. A crude, semi-kludgy system from 35 years ago still functions flawlessly.
There are certainly more parts in an EFI setup, but the frequency of failure for EFI parts is orders of magnitude less than the frequency of a carb falling out of adjustment. A good carb is indeed perfectly adequate, but, on average, EFI will be easier to live with on a day-to-day basis.
I have a 2017 1200cl and I have put 43k on it so far with no problems. Regular oil changes and maintenance and it’s good to go. I let it warm up completely before I ride to work and it does just fine. The only problems I have had are when it is really cold . When it gets down around 20 or so it has a hard time starting and takes a good while to warm up.
