Vance & Hines Pipes & The Fuel Pak System
RE: Vance & Hines Pipes & The Fuel Pak System
Correct, you would be better off getting the download (flash) for your ECM. Now, I am no expert, but I think with the higher end tools (like the SERT) you can do your own re-programming of the ECM, not sure about the PCIII, perhaps one of the experts would chime in about that. As far as I know, all the fuel pack does is ensure you get the right amount of fuel for the pipe/AC combo you are running but it does not alter the programming of the ECM. I would say you definately need the Stage 1 flash to get the best performance out of your scoot.
Hope this helps a little bit
Go with the fuelpak dude. Doesnt require a computer or extra tinkering. Does the same thing. The SERT is the exact same as the fuelpak unless you buy the full on computer accesory crap. Just dial in the numbers and roll on. Why make a fuelpak if its essentiall worthless? It piggybacks on the ECU to get the proper mixture. By the way, the pipes are sounding great and bike is running just great after drilling my baffles.
ORIGINAL: macgoph67
Like all things it's horses for courses. If it does what you want get the Fuel Pack; if you are going further, get the SERT (or even a replacement or additional ECU).
I have a sporters 1200 low and I am waiting for vance and hines to came out the new pipes for 2007 harley, but for now I don't have a choice to wait and wait , anyway thanksgiving its coming then christmas the new years and I won't have the money.
But I am saving hopefully for spring 2007 for now let's wait
tried searching for an answer and this thread came up...
I'm considering the V&H Shortshots Staggered w/ Quiet Baffles + V&H Fuelpak & Screamin Eagle Stage 1 AC on the Sportster Forty-Eight. A Couple questions:
1. How will this effect gas mileage?
2. Other then one being legal in CA what's the difference between the regular Fuelpak and the Fuelpak G/EX? What limitations does the California approved one have?
3. I'm doing this mainly for the style of the pipes and sound but is there really a performance difference at all from this setup vs stock? (not expecting miracles just curious)
man thanks for the heads up on that one! did some more research on them and since I'm not trying to drag race they definitely sounds like the winner.
A word on how the V&H pipes w/ Stage 1 AC and a "richer AFR" will effect performance and gas mileage?
I'm not too sure about the HD remap. It is a preset one time MAP download that may or may not work for your exhaust/AC setup. If it doesn't, then you are still stuck needing additional tuning. I have to agree with trying the X14's, or go another route with a tuner that can be dialed in on a dyno.
I am looking into getting the new Cobra Power Pro Auto Tuner.
I need to save my pennies and get one depending on reviews from other riders.
