Old 03-17-2015, 06:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
DIY - Air Cleaner
• Step by Step Instructions
• Parts Needs
• Visual Guide
Read full discussion below
Print Wikipost
Small, cheap & easy do it yourself air cleaner (lots of pics)
Old 02-01-2011, 10:32 AM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf is offline
Originally Posted by PAsportster
And if you want the cyl walls clean , run sand thru it....
Harley Davidson and the HDForums.com are not responsible for damage as a result of any comments made on this forum. This includes, but is not limited to, property damage to the motorcycle, rider, passenger, or property that the vehicle might damage should a malfunction occur, causing catastrophic failure.
Old 02-01-2011, 11:11 AM
RAL's Avatar
RAL
RAL is offline
Default Performance?
Changes in power, fuel consumption ect????
RAL
Old 02-01-2011, 11:38 AM
minalaker's Avatar
minalaker
minalaker is offline
Once again, excellent job Mreed! Very helpfull post.
Would a guy have to get his EFI bike re-programmed if he went this route?
Thanks again for the lesson.
Old 02-01-2011, 11:46 AM
kahaone's Avatar
kahaone
kahaone is offline
I have been wondering what air cleaner I'd do. And since I was not planning on spending several hundred dollars on anything....it looks like this will fit the bill perfectly! Thanks mreed!!
Old 02-01-2011, 12:10 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
Just remember you need to deal with the Crankcase venting if you do this. But that is a fairly cheap mod also.
Old 02-01-2011, 12:26 PM
ItsTomFromNorthJersey's Avatar
ItsTomFromNorthJersey is offline
i see you have the same air cleaner as i do, i didnt run the bike yet but i did install it. stupid question but is the crankcase venting incorperated with the j/m a/c?
Old 02-01-2011, 12:33 PM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
CHOPPIN' CHARLIE is offline
Doggit, I be ashamed & embarassed to admit what I just paid my H-D dealer for a K&N filter element to fit my stock '09 96" beloved one!
Old 02-01-2011, 01:48 PM
mreed's Avatar
mreed
mreed is offline
The crank case venting bits come with the carb mount. I just didn't put them on this one because I'm going to make something for it.
Old 02-01-2011, 01:50 PM
mreed's Avatar
mreed
mreed is offline
RAL
Yeah...you should be jetted or "tuned" the same as any other high flow air cleaner.
Old 02-01-2011, 01:53 PM
ryanmunar's Avatar
ryanmunar
ryanmunar is offline
Stage II
Originally Posted by mreed
The crank case venting bits come with the carb mount. I just didn't put them on this one because I'm going to make smething for it.
Very nice. I want to do this as well. I have a Sportster 48. Will i need the crankcase breather? Thanks.
Quick Reply: Small, cheap & easy do it yourself air cleaner (lots of pics)
