Small, cheap & easy do it yourself CRANK CASE BREATHER
Old 02-18-2011, 02:28 PM
schwingding's Avatar
schwingding
schwingding is offline
Originally Posted by mreed
With 40 microns I'll have atleast the same backpressure as yours.
I don't feel the need to argue it (and probably can't) but I doubt that is actually the case.
Your other points, I get.
Old 02-18-2011, 03:03 PM
mreed's Avatar
mreed
mreed is offline
Oh man I'm sorry...I didn't mean to come off as combative.
What is the filtration of your filter then?
And for the record...the stock set up is routed behind the main air cleaner for the sole purpose of what the filter offers. There's no pressure rhyme or reason with a stock set up.
Old 02-18-2011, 03:29 PM
schwingding
Actually that is not completely true. The reason, other than smog/CARB stuff, that the breathers vent directly into the venturi or throttle body is to pull air out of the breather tube/crankcase, rather than rely simply on blow by as is the case with a standard breather. The negative pressure (or simply decreased pressure) alleviates stress on valve seals, gaskets, and other more delicate surfaces (at least technically it does/can, I suppose that is debatable).
I did not pass my breather tubes by any filters, as they do in the stock case as you correctly stated. The little bit of oil burned inside the combustion chamber, while not ideal, isn't going to kill the beast. In the breather case as you've set up, you'll have oil drips occasionally onto the crankcase, even at 40 microns.
And finally, I didn't think you were arguing, I use the word argue/debate interchangeably. Sorry for the misunderstanding. Please don't get me wrong, I think you do neat work!
Old 02-18-2011, 06:20 PM
Lakerat's Avatar
Lakerat
Lakerat is offline
Back a long time ago, drag racers put crankcase evacuation tubes in their headers to get rid of pressure build up. I use them on my drag boat to keep oil from snotting all over the back endof my boat. Now they use an actual belt-driven vacuum pump to create a negative pressure in the engine. This mod allowed them to use low tension rings, providing more horsepower because of the reduced friction. Our Harleys aren't quite that exotic, but it can't hurt anything. Just food for thought.
Old 02-18-2011, 09:02 PM
mreed's Avatar
mreed
mreed is offline
Yeah, a friend of mine has a vacuum set up on his Camaro. Absolutely no noticeable difference other than no more oil splash out.
You would have to be tuned to the absolute top of the hill to even think that a Sportster would be affected one way or another by not having a positive pull to exhaust the crank case.
But, having said that, my wife's Buell Blast has a pretty nice umbrella valve set up from the factory. lol.
Old 02-18-2011, 09:21 PM
fattboy1967's Avatar
fattboy1967
fattboy1967 is offline
hey mike got these breather bolts ...THEN i read ur thread on how to make my own....live and learn...thanks again
Old 02-18-2011, 10:09 PM
mreed's Avatar
mreed
mreed is offline
Hey! Right on man!
Old 04-01-2011, 04:25 PM
northwoodsiron's Avatar
northwoodsiron
northwoodsiron is offline
mreed.....
i already got these but have not gotten all my parts together yet , are these the right ones for a direct fit?
and thanks again for your great right ups!
Old 04-01-2011, 08:55 PM
mreed's Avatar
mreed
mreed is offline
Originally Posted by northwoodsiron
mreed.....
Yep. Those are the ones.
Old 04-02-2011, 10:56 AM
XLOSTX's Avatar
XLOSTX
XLOSTX is offline
Sweet mod, I'll be putting this one on.
Thanks mreed
Quick Reply: Small, cheap & easy do it yourself CRANK CASE BREATHER
