V&H "sideshots" and my 2009 883n iron
Okay, here is my current status. I placed the front head pipe on (hand tightened flange bolt) but the rear pipe is nowhere close to a "bendable" position. It is at least 2" to the right. I did lay on the seat and attempt to pull into place, but I am still nowhere close. And before the jokes start I am not a puss*. Hahaha! I do have strength.
I don't remember everything I tried or exactly what worked except that I was draped over the bike pulling the rear header pipe into place. All I can say is you have to keep wrestling with it and moving things a little till you finally get it to go. Maybe try with the front loose and pulled to the rear of the exhaust port (but still over the fins) to get the rear header on then put the front into the port. You could also try sliding the flanges up the pipes till you get them over the ports then slide the flanges back into place. Oh, and stop being such a puss! j/k
BTW, my favorite line in the instructions (as I sat alone doing the install):
"8. Using stock flange nuts, carefully install head pipes into exhaust ports (Assistance may be required)."
Yeah, like assistance from God.
Oh, and don't plan on doing any hand modeling for a few days either. Their gonna look like you been in a fight (and at least you won).
Too bad you weren't able to do it yourself, I installed mine a couple weeks ago with the help of a friend. I was pushing and pulling while he guided the flanges on the bolt studs. After they are on and you put some mileage on the pipes they come off and go on a lot easier the second time. I had to take them off to put the forward controls on. Your gunna love the sound compared to the stock pipes!
