06 Sporty Custom n00b question
I just bought a 2006 Sportster 1200C. It started to run rough today, sputtering and popping. My riding buddy says its running too rich. It has a stage 1 kit. Should I take it back to the dealer to get the ECU re-flashed? I have only put 40 miles on it. Any thing else I should look into?
Your bike has a carb so there is no ECU to re-flash.
Check the rubber seals where your carb slips in the intake and where the intake mounts to the heads. The bolts could be loose or the rubber is bad. You can spray wd40 on the intake seals while the bike is idling to see if it skips worse.
There is more but this is a good place to start.
PS: The service manual for your year and make bike is your best friend. This is also covered in the troubleshooting area of the manual...
Were your 40 miles all one ride or a bunch of short ones? At what point did the bike start to sputter (at idle, at acceleration, while cruising). As mentioned before, your bike is carb'd and the symptoms you spoke of are the same thing the bike does when it's running out of gas. what position is your petcock in? Is the tank full?
frustratedHD
Exhaust System Topics
08-02-2011 07:15 PM
