Should not have read this thread. When for a ride today now MY BIKE is doing it!!
RAL
Sorry to jinx you.
I had it today as well.
Morning ride - no noise. Temp was in the high 70's low 80's.
Afternoon ride - NOISE. Temp was in the low 100's.
Evening ride - no noise. Temp was in the low to mid 90's.
It could also be the air inlet is plugged if it is not a mech. sound. If you open your gas tank is there vacuum?
I thought of that. I opened my tank and found no vacuum. I thought maybe it was low on fuel, but it is not that. I have half a tank. Its definitely not a mechanical sound though. I think it is generated by some time of air or fluid movement. The sound is there when at idle and does not increase in pitch, but does get louder when actually moving. The faster the higher the pitch. That's why I am thinking air movement.
It may be a vortex created by excessive throttle twisting.
this is an interesting idea! where did you get this idea from. this morning after sitting all night i had no noise.
but would this vortex continue thru out the day? because yesterday, i took a quick run to the walmart and noticed the noise. then back to work. hours later when i went to go home, it started again.
then this morning.... no noise...... so confuso
A heat dependant vortex.... Sounds like an X-file. Damn those gremlins! What will they think of next? Only solution to that is call in a witch doctor. Ting Tang Walla Walla Bing Bang Bang
Okay, despite filling up yesterday and the noise going away, it came back when I left from work this afternoon. Very hot outside and the bike was in the sun all day. So I definitely think that heat may have something to do with it.
Hmph.
It is related to gases in the fuel tank. Extreme heat like we have here in hotter than hell Miami causes the gas to evaporate and build up pressure in the tank. It happens every now and then (usually when low on gas).
I would take a look at the pump and hoses if it's happening constantly though.
