What exactly is the "Stage 1 download" and is it worth it
I would say yes. The bike I bought had a Stage I download, or so I was told. Also has very short aftermarket pipes. Bike ran ok but sounded like crap with backfires between shifts and very bad decel pop. Bought the super tuner and had the bike dyno tuned and now all that has been corrected. Added 9 hp and the bike runs great. Mind you this is a more expensive way to go but I'm very happy with the results.
I fully understand EFI, as ive been an automotive technician for 7 years. I know what the Xied's do for fuel, but from what ive found trying to search the stage 1 download is that it does not change the fuel tables BUT i couldnt find and exact answer to what the stage 1 actually does do. I would think that if it does change the ignition timing then that could benifit even more with the increased fuel from the xied's.
Waste of money, IMHO.
Alot of people knock the stage one accessories and download and that is fine, I believe everyone's opinion is valid, but people have to remember that many of us bike owners do not want to 1) spend a lot of money on tuners and dyno time, 2) do not want to bother messing around with tuning period.
Many riders just want to hop on their bike and ride. Stage one works great for people that just want to ride. You can go to the dealer get it installed and drive away with everything working fine. You don't "need" to pay for a tuner or dyno time.
Just my opinion.
Just my opinion.
Well, it's really not about opinions (opinions can be wrong). Personal preferences, I'd say. What is important for you, how you ride. I ride it hard, I know engines and EFI, and I'm kind of perfectionist. The result can be seen in my footnote.
Your preferences being different does not make you wrong.
A competent tuner with a dyno will be able to maximize your engine's potential with it's given components, absolutely. However, not everyone has dyno access, nor a competent tuner! Many tuners will simply tune for max HP, but not consider the value of trying to hit a nice flat torque curve. Others will tune it for wide open throttle, but not really consider how it'll behave at half throttle/cruising. A lot is up to the tuner himself.
Regardless, the SERT will be needed in order to perform the dyno tune, so you're already in it for the cost of that baby, plus the dyno and tuner's time. I recently paid about a grand for the SERT and a dyno tune on my vrod, but it was well worth it because that bike freaking runs like it's on fire now.
Also, once the dyno tune is done, if you change anything, it'll have to be done all over again, and you're in it for the dyno time and the tuner's time, but not the SERT a second time around, you'll already own that.
The stage 1 download is generally "close enough" for most riders' needs, and enough maps are available that a tune is usually able to be found for your specific combination of pipes/air cleaner/engine/etc.. it truly is a ripoff if they charge you for the download, too for more than about 30 minutes of time, all they do is plug the bike in and fire up the software.
Not quite correct. HD stage 1 download is supposed to make your engine work with your mods without damaging it while still conforming with emissions regulations. Performance-wise it is a far cry from unleashing the real potential of your engine.
