Improving the Willie G. Skull Gas Cap!!!
Okay so from what I can tell a lot of you have suffered through the disappointment of the Willie G. Skull Gas Cap. Because I liked the look of it so much I decided to fix its crappyness instead of returning it. Below are the steps and photos I took to make this improvement:
Disassemble the gas cap entirely:
NOW THROW AWAY THE SMALL 0.5" COIL SPRING! THIS IS JUNK!
Plug the position lock channel up so the cap cannot twist around as much. I used a paper towel.
Place the circular spring inside the top of the gas cap screw.
Put the plastic position lock in place. Make sure to push it all of the way down on top of the circular spring.
Add the silver ring around the cap screw so that it stays on upside down.
Push the cap screw assembly into the cap as hard as you can!
Put the gas cap back into the bike!
Now enjoy your Willie G. Skull Gas Cap! It won't twist around as freely as it did before and it certainly doesn't fall apart as easily as it did before!
My Skull Gas Cap just fell down due to a bump on road, Now I'm unable to fix it
I can read the steps you wrote but cant see the images you've posted below the steps, dont know why but these images are not displaying either on laptop or phone. can you please share these photos over email? hamzaazeembutt@gmail.com
Vikingnomad
10-22-2014 04:32 PM
