Turn Signal Wiring
I wouldn't be that positive about it. You should ask Kuryakyn because they have L.E.D. systems for many year-bikes and are knowledgeable about this. Just pretend you want to buy those lights from them.
Remove either the front or rear bulbs and test out the other set...on my 08 N the only thing I notice is a SLIGHTLY faster blink rate. If this is the case, you can run LED in either the front or back side. I don't think you'll be able to run LED all the way around without a load equalizer.
I just went through hell trying to find a suitable drop-in for the rear side and ended up with Custom Dynamic's tail lights. They should be here today. In the front, I plan to run amber 2457 incan bulbs.
When I run into a bike that is being switched from a 3 wire light to a 2 wire LED light, I make a converter that will run the LED's at about half brightness for running lights then full brightness for turn/stop. and they take up no more room than a pair of wires next to each other.
how would I do that?
also these are the ones I picked up http://www.jokermachine.com/itemstre...&Placeholder=0
Joker LED
I also want to get a pair of Jokers led, from what I have read you have to use http://www.jpcycles.com/product/320-469 so you have running lights with turn signals, if you hook them up with 2 wires you will not have running lights.
Now with that being said, I have to figure out if the Badlands load equilizer will work with this module above.
http://www.youtube.com/watch?v=-dSo8ufvU_4
any of you guys know how to get that setup done all round???
That is because you only removed ONE of the front bulbs and it thinks it's blown, try removing BOTH and try the test again. It MAY fast blink for a moment until it figures out what is going on. You may even have to turn off the signal, then reapply...it seems to learn what is going on rapidly. I haven't had any issues with my LED tails and 2457 front bulbs, nor did I have any issues running 1157's up front with nothing in the rear at all.
This should help....
http://jokermachine.com/products/har...converter.html
I just finished the install on these http://jokermachine.com/products/har...er-lights.html
The above link should take you to the piece that will allow your new marker lights to be multi-functioning.
