Clutch/Brake lever replacement.
Old 04-20-2012, 09:41 PM
edgeofinsanity's Avatar
edgeofinsanity
edgeofinsanity is offline
Originally Posted by jerryw618
I have all the tools and ive done clutch lever and clutch cable replacements , i am just not sure where the little brake light switch is on the brake lever to put tha cardboard in ? i guess ill have too drive up too storage and dig out my shop manuals
The switch is in between the throttle control housing, and the brake lever, it looks like a pin. When you pull your brake lever, the "pin" comes out, but if you remove the lever and try to put it back on with the pin still out, it could/will break that switch.
Stand in front of the bike, then push the brake lever in. As it pivots there will be a gap at the right side of the lever, near that pivot pin. That's where the cardboard goes. I like to use a zip tie, folded over to double thickness. Jamming the tie or cardboard acts to keep the lever like it's pulled in slightly, enough to clear the switch as you take it off and on.
Old 04-21-2012, 06:16 AM
waynerds74's Avatar
waynerds74
waynerds74 is offline
Are you sure you can't blend/sand out the scratches??? Before you rush out and spend lots of cash, try getting a really fine sand paper and blend out the scratches...you'll be pleasantly surprised how easy it is.
Old 04-21-2012, 09:46 AM
nhrapt's Avatar
nhrapt
nhrapt is offline
Default Debrix cycles
+1 on debrix cycles.
Old 04-27-2012, 12:31 PM
studiopeg's Avatar
studiopeg
studiopeg is offline
Thanks for posting this... I was going to attempt to change both my levers this weekend and glad I saw this first!
Old 04-27-2012, 02:50 PM
jerryw618's Avatar
jerryw618
jerryw618 is offline
Thank you for the help i spotted the switch and i did as you said with the cardboard spacer but then i loosened the brake lever/brake fluid resivour bolts and slid the assembly away from the switch housing then i was able too replace the lever and move it back into place without damaging the switch took like 3 minutes too complete . thank you again for the input it gave me the confidence boost to tackle this job and not muck it up. looks really nice with the new chrome levers .
Old 01-06-2013, 03:21 PM
Tyree's Avatar
Tyree
Tyree is offline
Like already posted, clutch lever is easy. I rerouted my clutch cable due to installing higher bars, and took the lever off so I could just run it through the front forks, rather than remove the headlight. From what I remember:
For the clutch side, you'll need a snap ring tool, or some small needlenose pliers and a new snap ring. Start by sliding up the rubber cover on the clutch cable, near the frame, it should be clipped to the frame with some wires. Loosen the locknut under the cover and adjust the cable putting in as much slack as you can. The lever is attached to the controls with a pin, which has that snapring on the underside. Remove that snapring, and the pin comes out, then just pull your loosened cable through the control housing. There is a small black "clip" looking thing on the underside of the clutch lever, it's there so the lever doesn't vibrate. Take it off (single black phillips head screw) and put it on the new lever. Attach the cable to the new lever and put it back together, then readjust the clutch cable (1/16" to 1/8" slack at the lever).
Not sure on the brake side.
Thanks for the instructions. I spent an hour trying to follow Harley's various instructions, then a quick Google search and a five minutes later I'm off to the next project.
Bill G
14
07-01-2019 06:45 AM
glcash
2014-2023 Touring Models
01-14-2017 05:51 AM
WG2011
03-31-2015 09:24 PM
JohnTM
02-12-2014 09:26 PM
jcanrun
10-14-2009 06:15 PM
Quick Reply: Clutch/Brake lever replacement.
