adjusting carburetor at higher altitudes
'06 883c
what should i do with the carb settings to allow the bike to perform better at higher altitudes and at what altitude should i do this doing the smokey mountains and the blue ridge and in some areas the altitude will be like 6,000 ft i believe that is enough to have a big impact on the performace is resetting it easy or difficult |
I'm a frequent rider in the Smoky Mtns. You will notice a slight difference above 4,000 feet, but those elevations are rare.
The easiest way to quickly adjust is to get a speed screw for the air fuel mixture. Then, it's just a simple small turn with your finger and thumb. I really don't think you will notice much difference. There are very few places in that area that are over 3,000 ft. |
thanks
i am asking because going thru colorado at elevations of 11k ft, the bike was hard pressed to get above 45 mph going uphill. just wanna make sure that don't happen again |
low speed mixture will not help, its out of the picture at 1/8 throttle.
you will be rich at altitude. it can be adjusted with different main , and needle. however when you get back down to a lower altitude , it will be way lean.. Now rich at altitude wont hurt anything except power/fuel milage . lean at lower altitude can destroy your motor. For one trip , I would just put up with the lack of power |
© 2024 MH Sub I, LLC dba Internet Brands
