A pick and a 1200 question
Just a litte rip around on the brutal 883 who can easily snap your neck with a tiny blip on the throttle
is there cheap and simple kit on the market if i just want to go 1200cc with pistons and maybe cylinders and use everything else stock, has anyone done it ? worth it ?
John Harper (10-15-2023)
If you have a pre-2008 (?) 883 you can bore the cylinders and buy conversion pistons (Wiseco?). It is not necessary to have 1200 heads. I have a Hammer 1250 kit and use my stock 883 heads with no issues. Boring and Wiseco conversion pistons is probably the cheapest way to a 1200, with a 1250 kit probably a close second. Considering the Hammer kit comes all ready to go versus finding a machine shop to do the boring, honing, fitting pistons, gapping rings, etc. I guess it's up to you which would be cheapest path.
If you have a post 2003 bike, you'll also need to upgrade the clutch spring to a 1200 version.
John
John
jyx (10-15-2023)
The following 2 users liked this post by Madnss:
96hugger (10-21-2023),
hammer6315 (10-21-2023)
The pictured bike is a 1991-2003, which is carbureted. Although a new ignition is recommended, he can get by with just an adjustment of his spark timing. The only other thing he needs is less that $10 worth of jets for his carb.
The following 4 users liked this post by aswracing:
thank´s guys, i´ll look into this during wintertime and hopefully i can have a bit more power in the oldy but goldy little sporty by next riding season. The bike started life as a 1989 883 Hugger but the motor, wireharnes, speedo, fork, hand controlls, brakes and swingarm is from a 2000 Custom.
DeluxeCruiser
05-22-2013 11:08 AM
