baffle plugs
Old Oct 9, 2012 | 06:53 PM
Sancheese's Avatar
Sancheese
Default baffle plugs
Punched out baffle plugs on my se1 and I swear the bike is faster and louder
Old Oct 10, 2012 | 04:43 AM
roundy's Avatar
roundy
Probably not....just feels that way because now you hear it more you ride it harder ;-) If anything (and please peeps correct me if I am wrong) you'll loose back pressure which will effect performance...?
Old Oct 10, 2012 | 05:57 AM
mrfikser's Avatar
mrfikser
I did the same on my Se mufflers and it does seem to be faster in the higher RPMS..but I also jetted it up a size at the same time...
Old Oct 10, 2012 | 07:44 AM
schwingding's Avatar
schwingding
Not likely. Probably performs less well in non WOT operation to boot. Typically when sporties are run with wide open pipes their performance decreases in mid throttle application, but WOT will probably be about the same. If this is an EFI bike, WOT might be worse off as well. If you're happy though, who gives a *****?
jkhawaii
Exhaust System Topics
May 10, 2018 09:55 PM
jlasoftail
Aug 19, 2016 06:54 AM
Alleyn
May 22, 2012 10:37 AM
gpp
Feb 14, 2008 09:28 PM
hondo96inch
Oct 1, 2007 12:31 PM
