Bike runs, shifts thru gears - but doesn't move - SOLVED
Hey guys,
Please forgive my ignorance, I'm new to Sportsters. I have a friend who has asked me to help him repair his bike. The details: 2007 Sportster Nightster 1200 The bike starts without issue and runs well. While running, it can be shifted thru all 5 gears, and the bike does not move one inch. What I have been able to rule out follows below. I wrench a lot on the Softails and Touring bikes, but Sportsters are still new. Any help is appreciated. 1. It's not the drive belt - I thought maybe that there were several teeth missing from the belt and that the stripped spot was on the pulley, not catching the splines. This is not the case. 2. It is not the clutch cable. 3. When looking thru the small inspection cover on the primary case, the primary chain is in tact, and appears to be free of damage. 4. Putting the bike in 5th gear, I had him roll the bike back and forth. It was not running, and the clutch lever was out. While doing this, the primary chain slack would take up while rolling backwards. Rolling forwards, the slack didn't take up. I know this is an issue. 5. I had him start the bike while observing the primary chain. It spins while the motor runs. He was doing burnouts in his driveway and neither he nor his friend heard any strange noises. I plan to start by pulling the primary cover off to observe what is going on. I don't have a Sportster Service Manual, but I told the owner to invest in one. Does anyone have any advice or insight? Maybe pictures of the inner primary exposed for reference? Thanks. |
First slap the owner for doing burnouts in his driveway.
Then tear down the primary like you said and I bet you find what is wrong right away. Somehow I bet you find metal flakes/shavings/pieces from one of the two pullies. |
Originally Posted by Redbeard719
(Post 10534297)
Hey guys,
Please forgive my ignorance, I'm new to Sportsters. I have a friend who has asked me to help him repair his bike. The details: 2007 Sportster Nightster 1200 The bike starts without issue and runs well. While running, it can be shifted thru all 5 gears, and the bike does not move one inch. What I have been able to rule out follows below. I wrench a lot on the Softails and Touring bikes, but Sportsters are still new. Any help is appreciated. 1. It's not the drive belt - I thought maybe that there were several teeth missing from the belt and that the stripped spot was on the pulley, not catching the splines. This is not the case. 2. It is not the clutch cable. 3. When looking thru the small inspection cover on the primary case, the primary chain is in tact, and appears to be free of damage. 4. Putting the bike in 5th gear, I had him roll the bike back and forth. It was not running, and the clutch lever was out. While doing this, the primary chain slack would take up while rolling backwards. Rolling forwards, the slack didn't take up. I know this is an issue. 5. I had him start the bike while observing the primary chain. It spins while the motor runs. He was doing burnouts in his driveway and neither he nor his friend heard any strange noises. I plan to start by pulling the primary cover off to observe what is going on. I don't have a Sportster Service Manual, but I told the owner to invest in one. Does anyone have any advice or insight? Maybe pictures of the inner primary exposed for reference? Thanks. Cold - 3/8-1/2 in. (9.53-12.70 mm) Hot - 1/4-3/8 in. (6.35-9.53 mm) Lets hope, but it sounds more like, you don't find a problem like the one discussed in this thread. https://www.hdforums.com/forum/sport...tch-alert.html |
Originally Posted by DOMAPOI
(Post 10534672)
I don't think you have to worry about your point #4. The chain will naturally pull up slack turning one direction and will naturally feed slack going the other direction since the tension is taken up on the bottom and fed to the top.
Lets hope, but it sounds more like, you don't find a problem like the one discussed in this thread. https://www.hdforums.com/forum/sport...tch-alert.html But about my point #4...if the bike is in the highest gear, and the back wheel is turned, that should in turn rotate the gears in the transmission and then the primary chain, and lastly the crank in the engine. That isn't the case with this bike in its current state... I appreciate the ideas! Please keep them coming. |
I'd also make certain that the splines on the secondary drive pulley haven't stripped (that's the front pulley on the right side of the bike)
Originally Posted by 1984_FXRT
(Post 10534983)
(Post 10535283)
Thanks for the tip. Are those splines prone to stripping off?
You understand once you touch this Friends bike you will then “Owen” it for the rest of your life.
(you understand this statement from a mechanical / repair point?) :) Just my $0.02, I would help find the problem but I would recommend a shop to fix it. :) It does sound like a clutch problem. |
Originally Posted by Kenney
(Post 10535401)
Wat's the mileage on the bike? If it's had your friend's treatment for some time I would not be surprised if the clutch is shot. |
(Post 10535401)
Originally Posted by hhkiwi
(Post 10535445)
I agree, that does sound like a clutch problem. If there was damage to a spline I would expect you to hear unusual noises when the engine is running and the bike is in gear.
Wat's the mileage on the bike? If it's had your friend's treatment for some time I would not be surprised if the clutch is shot. I was thinking this as well. The splines seem to be intact, as when the bike is in gear and the wheel rolls, there is some slack taken out of the primary chain, plus it wasn't noisy when running. The bike has about 8,000 miles, and he's had it about 2 months. Previous owner was an older couple that putted around town from time to time. I guess worst case scenario (thinking out loud here) is that the transmission could be ruined. I doubt that is the case, but it's possible. Are the transmissions in the Sportsters pretty solid? |
© 2024 MH Sub I, LLC dba Internet Brands
