Just bought a 94 1200 stock with drag pipes
Old 02-13-2013, 04:01 PM
Ms54Coupe's Avatar
Ms54Coupe
Ms54Coupe is offline
Default Just bought a 94 1200 stock with drag pipes
What should I do put stock pipes back on?
Old 02-13-2013, 04:10 PM
1984_FXRT's Avatar
1984_FXRT
1984_FXRT is offline
Stock head pipes w/free flowing slipon mufflers are the best bang for the buck exhaust.
Drag pipes suck for street use, and are horribly inefficient at anything less than a very narrow RPM range at WOT.
Look on Craigslist and eBay - lots of stock pipes available for cheap.
Old 02-13-2013, 04:12 PM
John Harper's Avatar
John Harper
John Harper is online now
Received 1,647 Likes on 1,136 Posts
Why? Have you checked for upgraded air cleaner and jetting? What is "stock with drag pipes" supposed to mean? How about lollipops or DK Torque inserts if you have a flat spot?
John
Old 02-13-2013, 04:20 PM
nc883's Avatar
nc883
nc883 is offline
I think they mean a stock bike except for the drag pipes.
+1 on carb & air cleaner upgrade. Go forwards, not backwards....
Old 02-13-2013, 04:38 PM
Madnss's Avatar
Madnss
Madnss is offline
Received 1,053 Likes on 569 Posts
Put an air cleaner on and run the he'll out of it. I ran drag pipes for years. Just fine.
Old 02-13-2013, 05:19 PM
Ms54Coupe's Avatar
Ms54Coupe
Stock bike with the exception of drag pipes is what I meant. There is absolutely nothing else done to the bike.
Old 02-13-2013, 05:49 PM
DK Custom's Avatar
DK Custom
DK Custom is offline
Platinum Sponsor
Received 3,940 Likes on 2,295 Posts
If you like the sound of the drag pipes, leave em on and put some W118 Thunder Torques in them. You'll gain some serious low and mid range power and the tone will deepen a little.
Clicky
__________________
Kevin
DKCustomProducts.com
Call/Text: 662-252-8828
Old 02-13-2013, 05:56 PM
MO-FO's Avatar
MO-FO
MO-FO is offline
Stage III
stock pipes are boring harleys should be loud just tune it for your pipes and ride the hell out of it and have fun
Old 02-13-2013, 06:21 PM
Madnss's Avatar
Madnss
Madnss is offline
You can also shove a bolt threw the end of the drag pipes, 1/4" bolt on each pipe. A bolt threw 1 3/4 open drag pipes will run with any baffle or tq cone out there, hands down.
Old 02-13-2013, 06:22 PM
Madnss's Avatar
Madnss
Madnss is offline
Yuppers! We are the minority though.
Quick Reply: Just bought a 94 1200 stock with drag pipes
