Battery and Check Engine Light Question
I'm sure i'll hear it from some of you to search the threads, I have. It still didn't answer my question. I know i need to take it in to get it serviced. It either the Voltage regulator or the stator. I don't have a voltmeter to check to see which one.
While riding after being on trickle charger, a few miles into the ride both lights come on but go off. And it does it several times throughout my 10 mile commute to work. Starts with no problem at the end of my shift and the lights do the same thing again, coming on and off several times on the way home. Is there anything that i should be worried about during the trip? Like will my bike just die? If I keep it on the charger can I still ride until I get it to the dealer?
Oh yea, my bike is a 2012 Nightster. I got her on my Anniversary last year on St. Patricks Day. The wife knew I wanted another bike after I totalled my Vulcan 900 several years back.
Usually after that it's a voltmeter. It's really an indispensable tool for working on your bike. The one I use was about $20 at Lowes, so don't feel like you need to go out and get a professional gauge or anything.
Easy check would be battery voltage while running. That will tell you if your regulator and possibly stator are good or not. Then you can follow the procedure to unplug them and actually test stator output.
If the stator is bad, you'll just get stranded, which is no fun. If the regulator is fried and overcharging your battery you could (worst-case) blow up the battery, but more likely you'll just pop a fuse or cause it to stop working, thus leaving you stranded.
Honestly, I would park it if you can until you can at least verify you're not getting overvoltage at the battery. That can really fry some electrics or worse. Electrical problems have a way of spreading if they aren't fixed.
If you absolutely must ride it to and from work, just get a voltmeter at the next opportunity possible.
for future if you get a meter ... btw radio shack has a range of meters from 24$ to 89$
they are also good for home and car applications so its just not for ur bike
a meter will also let you trace wires a whole lot easier !! for 25 bux u cant have a better tool in the box , as its uses are wide
If you're facing the same issue, then you're compensating for any discharge during your short trips by your overnight trickle charge - but as Scuba10jdl cautioned above, this can't be considered a fix. I read in a German HD forum the bike will drain the battery and die on you after about 30 mi continued riding. Guess you check w/ the stealer if your VIN is affected, or log in at the MoCo to get the Recalls information (http://www.harley-davidson.com/en_US...e-recalls.html)
Just joined the forums over here, but I bet the whole 2012 Voltage Regulators story is right around the corner.
Cheers,
Jan
