94 HD Sportster 883 How Much Transmission Oil Change
hi everyone,
I'm changing the transmission oil for 94 HD Sportster 883, how much does it take? full 1 litter ? i tried to search the forum, but not getting an answer. |
One quart 75W90 gear oil or 20W50 motor oil. I use Mobil 1 gear oil.
John |
Check on that...I'm thinking 24 ounces.
My FSM says 24oz in one section, 40oz in the other, but to fill to the overflow hole took 32oz. Oddly, splitting the different manual recommendations gives one 32oz as well.
John |
1 quarter & 32oz is little less than a liter, 40oz is over liter, so how much should i put?
it's 94 883Hug, 5 Speed. |
If you have an oil level plug, remove the screw and fill it until oil comes out of the hole.
Originally Posted by 83XLX
(Post 11900294)
On the newer, rubber mount engines, you add a liter, but that basically means you just pour it in until the level is just below the lower opening for the round primary cover. The manual shows the oil level overlapping with the teeth on the clutch side sprocket as the "full line" but it works out to 1 liter, or "pour it in until it flows out the place where you are adding fluid". YMMV, but if you take the cover off and look, it should be apparent where "full" is. |
(Post 11900294)
John |
This Link seems to have right information with pictures.
about 950ml of oil, correct me if i'm wrong. |
© 2024 MH Sub I, LLC dba Internet Brands
