Air Cleaners
RE: Air Cleaners
ORIGINAL: Ice_Rider
I also plan on getting a full system exhaust, probably Samson Big Guns III. I was just wondering what air cleaners returned the best gains.
RE: Air Cleaners
I have Screamin Eagle Air Cleaner with Cycle Shack Slipon mufflers and am quite satisfied. There may be better options, the only thing I have to compare mine with was the stock setup. Two particular things I liked about those choices, Cycle Shack - GREAT PRICE. Screamin Eagle A/C, I got to keep the stock cover. I personally like the ham can appearance.
RE: Air Cleaners
I suggest for the A/C you look at Big Sucker, NRHS HurricaneFlow & Forcewinder. They all out perform the SE and give you the ability to reroute the rocker oil bypass away from the A/C filter.
Your carb was designed to mix fuel & air, NOT fuel, air & oil. Only the Forcewinder is a "RAM" air system. Ram air requires a forward facing opening so that as speed increases the air is forced through the filter into the carb intake.
RE: Air Cleaners
ORIGINAL: 1200c
Another I would add to the list is the Powerpacc. That also has a velocity stack in the backing plate. It is a round filter that is less expensive than the hurricaneflow.
Ram air is a nice theory. Forget about it for sportsters; it's irrelevant. RAM air doesn't do it's magic until like 150 mph. You would have to change the gearing on your sportster to even attain that and I am totally ignoring the problem with aerodynamics.
RE: Air Cleaners
I agreeon the "ram" air theory although I belive above 60 or so a true "ram air" scoop would start to provide a benifit. I was only countering DallasTX's claim that his SE A/C and other high flow A/C's are ram air.
