grip recommendations
Old 07-22-2014, 12:11 PM
edgeofinsanity's Avatar
edgeofinsanity
edgeofinsanity is offline
I'm rocking the Avon coke bottle grips. I had the Biltwell Kung-Fu grips, and they were comfortable, but only lasted a season before they started to fall apart.
Old 07-22-2014, 12:59 PM
Mr_Didwork's Avatar
Mr_Didwork
Mr_Didwork is offline
6th Gear
Originally Posted by Bagged64
I first used Performance Machine contour grips a couple years ago, but have since changed to the Avon contour which is the same grip, but cheaper price. They are on all my bikes. They are not soft, but are sticky and skinny. I had the same problem with my hands, because the grip was too fat. These have solved that problem. You can also buy replacement rubber for like $11 if ever needed.
+1 on this. Have the same grips and love them.
Old 07-22-2014, 03:26 PM
TF9030's Avatar
TF9030
TF9030 is offline
Originally Posted by Architect
Kung Fu grips from Biltwell were super cheap and work great for what you are looking for. They also look cool and have the best name ever for a set of grips!!!
Agreed. I also have the Kung Fu grips on my bike. A lot better than stock and only $20.
Old 07-22-2014, 09:44 PM
firsttwincam's Avatar
firsttwincam
firsttwincam is offline
6th Gear
the summer gloves say River Road, I know it was called a antique finish, my medium have a an "A" symbol sorta like an anarchy style, cant read anything, they are my oldest. & the winter pair is put up, but will go look if you need me to, & I have rode 900 + miles with some aluminum Kuryarkyn grips that had rubber in circles around & they were a little better than the previous solid aluminum but not by much. & that was on an old shovelhead chopper, a good grip & gloves will make a difference. I actually like the aluminum grips with rubber strips that float, & run from side to side all the way around, that & a gel insert glove. as a side note, 2 pair were bought from jap bike dealers catalog, my winter pair was from an online auction, for a motorcycle forum, & the widow of a stunt rider that got killed playing on the street, donated all his belongings to the forum he loved, to raise money for the forum & I was high bidder for the gloves
Old 07-23-2014, 09:03 AM
Kenny94945's Avatar
Kenny94945
Kenny94945 is offline
FWIW If the OP hands go numb, baring arm spine etc issues, OP states he believes it is due to his grips.
1) Don't hold on so tight.
2) Readjust handle bar angle.
3) Add a throttle boss.
4) Add gel palmed gloves.
5) Try a coke bottle shaped grip.
So many grips to choose from. Thickness, softness and shape being function. Design being form. Only the OP can choose, yet to cure his numbness he needs to look at the function portion.
Old 07-23-2014, 09:15 AM
heybaylor's Avatar
heybaylor
heybaylor is offline
If you have a throttle friction screw, tighten it so that the throttle stays where you set it .
you have to increase , or decrease throttle by hand ..real easy .
Now you don't have to hold against the spring constantly.
You can even pick your nose with your right hand
Old 07-23-2014, 12:39 PM
Traxxtar's Avatar
Traxxtar
Traxxtar is offline
Grips don't solve all vibration problems; they can certainly help, but your handlebar is buzzing/vibrating at a specific frequency based on engine RPM. Search online for ways to reduce the vibration first, handgrips second.
Old 07-23-2014, 07:55 PM
falsealarm's Avatar
falsealarm
falsealarm is offline
Default gloves
I bought a pair of gel lined gloves for my mountain bike.
great for the Harley
about 30 bucks
Seems like the different grips I had never really solved the problem, but the gloves did
Old 07-23-2014, 09:17 PM
83XLX's Avatar
83XLX
83XLX is offline
These grips are really good, and they're cheap, too.
http://www.directcycleparts.com/hand...el-p-4499.html
Old 07-23-2014, 10:25 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
I suspect your bars are the likely cause of this problem vs. grips ...
Quick Reply: grip recommendations
