Installing Screaming Eagle SP slip-ons. What do I really need?
Old 09-11-2014, 02:54 PM
mydogfarted's Avatar
mydogfarted
mydogfarted is offline
Default Installing Screaming Eagle SP slip-ons. What do I really need?
I know HD recommends new clamps for the mufflers. Bike is almost a year old and less than 5k miles on the clock. Do I really need new clamps?
I've seen a lot of people recommend new gaskets for the balance pipe. I've also seen a lot of complaints about the stock mufflers being a pain to get off. WD-40? Some other lubricant spray?
Old 09-11-2014, 03:21 PM
TF9030's Avatar
TF9030
TF9030 is offline
I used the same clamps and balance pipe gaskets when I installed my slip-ons. No leaking and haven't had any issues since. Just make sure the gaskets are in good condition.
I used WD-40 and just let it sit for a while, made things a bit easier haha.
Old 09-11-2014, 05:54 PM
Guzzi's Avatar
Guzzi
Guzzi is offline
Nothing but a firm grip to pull the stock pipes off.
Old 09-11-2014, 06:58 PM
sioux565's Avatar
sioux565
sioux565 is offline
Some WD-40 where the old mufflers and headers meet. I would get new clamps and gaskets for the cross-over. I did to prevent any issues. It is only an extra $10-$20.
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
gloves, wrenches, patience, maybe replace the little silvery dampeners that go on the muffler contact points. (worst description ever, ask the dealer, they know what i'm going on about)
maybe better to use a socket set. bout and hour if the refuse to come right off. reuse the old hardwre like mention above. easy
Old 09-11-2014, 08:10 PM
Switchback12's Avatar
Switchback12
Switchback12 is offline
Crossover gaskets on mine looked roached, they are delicate. My pipes were 8 months old and they were a PITA to get off for some reason. New ones easy on.
Old 09-11-2014, 08:11 PM
mydogfarted
It was easy. The Screamin' Eagle mufflers come with new gaskets for the balance pipe. The clamps needed a little spreading to fit over the new pipes. Done under an hour.
Old 09-11-2014, 08:18 PM
scooter1128's Avatar
scooter1128
scooter1128 is offline
you should be fine reusing the clamps on the mufflers. they are designed for one use but I have reused them a couple times. if they leak around the muffler, no amount of tightening will stop it (my experience anyways). by the way, the clamps aren't very expensive if you should need to get them. the balance tubes I'd definitely replace. pita to have to pull off and redo. bit of advice...put some anti-seize in the end of the muffler where it slides up on the exhaust pipe that way next time you want to remove the mufflers, it wont be much of a struggle to getting them off
Old 09-11-2014, 08:20 PM
scooter1128
see you posted before I added my suggestion. glad it worked out without any issues
Old 09-11-2014, 08:41 PM
cvaria's Avatar
cvaria
cvaria is offline
merry x-mas!
try to find some old evil SEIIs if you want the evil harley racket
Quick Reply: Installing Screaming Eagle SP slip-ons. What do I really need?
