I'm thinking of fitting the rear light set from Rick's. The local dealer tells me that this will set off engine warning lights etc though. In fact they claim this will happen with any aftermarket set not just the Ricks ones.
Does anyone know if this is really the case or are they just being overly cautious?
The cable and harness down on the swing arm where the factory tails plug in is just an extension. You can plug aftermarket lights in behind the plastic cover where you unlock the seat. Just as an fyi
The cable and plug in down on the swing arm where the factory tails plug in is just an extension. You can plug aftermarket lights in behind the plastic cover where you unlock the seat. Just as an fyi
