Mark this thread as Unsold
HD Black Rubber Heated Hand Grips - $100 Shipped
Came off my 2016 Ultra Limited FLHTK...they work great, just switched to a different style. I rode with them, so they are not brand new take-offs, but it good condition.
From the HD Site
Harley Davidson OEM Black Rubber Heated Hand Grips
Part Number 56100034
Keep comfortable on those cool morning or frigid night rides. Warm hands have a major impact on overall body comfort, and sometimes gloves just aren't enough.
Thermostatically controlled grips have variable heat settings and automatic temperature monitoring to adjust to changing ambient temperature
Grips remain at a constant temperature regardless of changes in outside temperature
Self-contained control circuit and control **** means no additional switches or controller boxes to mount
Shut on/off with ignition to avoid draining battery
Glueless grip design allows grip removal if you change handlebars or motorcycles
You get it...the keep the paws toasty...
From the HD Site
The site says: Fits '16-'17 Dyna® FXDLS, '16-later Softail® and '08-later Touring and Trike models with Original Equipment Stainless Steel handlebars. Does not fit CVO™ models or models with chrome handlebars. '16-later Softail® models require separate purchase of Electrical Connection Kit P/N 72673-11. '14-'16 Touring and Trike models require separate purchase of Electrical Connection Kit P/N 69200722. '17-later Touring and Trike models require Electrical Connection Kit P/N 69201599. Does not fit ’08-’13 models with internally wired handlebars.
you can find that HERE for HD HEated Grips on the HD Site - the part that says it doesn't fit the earlier internally wired bars, I "think" you can just get the Namz Extensions which makes them work there...I actually got those for mine when I put on my 14's...but didn't need them...
Also here is the Install Doc which talks about the other models it fits and where adapters are needed...again, on my 2016 Ultra Limited, it was prewired for them and completely plug and play....
multihdrdr
Touring Parts
11-24-2014 08:57 PM
