P1 Run Flat Size and Air Pressure
The 180/65-16 factory tire will be the same as a 195/60-16 car tire in height and 6 tenths wider. Going metric route there is no exact swap but some run the
205/55 -16. Speedo will be off a bit and slightly wide may not be the best idea. It is up to you.
We run the car tires with sidecar rigs. An argument I am not having but may not be a good idea on two wheels when the factory tire will give to 20K any way.
