The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
Darkside tire pressure?
Old 04-28-2024, 06:10 PM
deadhawg's Avatar
deadhawg
deadhawg is offline
Received 1,740 Likes on 670 Posts
Default Darkside tire pressure?
For those running a 195/60/16 car tire on the rear, what pressure do you usually run? I've been running 32-34 PSI on my '16 Roadglide, but noticed the tire is wearing much more in the center than on the edges. Of course, this is on a sidecar rig so leaning is not an issue.
smitty901 (04-28-2024)
Old 04-28-2024, 07:04 PM
smitty901's Avatar
smitty901
smitty901 is online now
Received 9,835 Likes on 5,287 Posts
Originally Posted by deadhawg
for those running a 195/60/16 car tire on the rear, what pressure do you usually run? I've been running 32-34 psi on my '16 roadglide, but noticed the tire is wearing much more in the center than on the edges. Of course, this is on a sidecar rig so leaning is not an issue.
38 psi. With either the 195/60R16 or 195/65R16
And of course that is with sidecar. I swap wheel back to factory when sidecar is off.
deadhawg (04-28-2024)
Old 04-28-2024, 07:43 PM
Hoginedgewood's Avatar
Hoginedgewood
Hoginedgewood is offline
Received 1,192 Likes on 653 Posts
Check the tires instructions, what rim do they recommend? Im seeing some car tires people use like a wider rim than the 5" i have.
i dont have a side car, but my middle is giving the outside edges a run for the money.
I initially used 40 psi, but im backing down to 35
