The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
Gone to the Dark Side - Ongoing Review
Old 02-21-2018, 07:03 AM
jc15025's Avatar
jc15025
jc15025 is offline
Looking forward to hear how your ride is with the new bike going dark.. JC
Originally Posted by PFWiz
Congrats and good for you. Let us know how you like the the tire.
I have made the decision that as soon as I get the new bike home she gets a car tire. I will not even wait to wear out the tire that comes on it.
  #132
Old 05-02-2018, 07:46 AM
PFWiz's Avatar
PFWiz
PFWiz is offline
Just when you thought it was over....
With 71 miles on the odometer I took my brand new 2018 Sunglow Fade CVO Limited to my indy and had them install a BRIDGESTONE POTENZA RE960AS POLE POSITION RFT 195/55 - 16 with 2 bottles of Ride On.
You can say a lot of things about me, but one thing you cannot say is that I do not put my money where my mouth is.
It took 4 guys to hold the upper sidewall down as the machine slid it under the rim. The good news is that it only took about 40 psi to get the bead to seat!
I am currently running 34 psi cold and the HD TPMS throws a low pressure fault every time I start the bike. Is there any way to adjust the low press set point? On a 80 degree day riding 2 up at 70 plus the pressure climbed to 39 psi.
The Ride On makes the bike ride smooth as silk and this bike with CT handles better than my 2011 RGU did with the GMax. Maybe those of you who said run flats where the way to go are on to something!
I will try to get some pictures in the next few days.
perki48 (05-02-2018)
  #133
Old 05-02-2018, 08:13 AM
67Shuv's Avatar
67Shuv
67Shuv is offline
Excellent!!!
  #134
Old 05-02-2018, 11:40 AM
perki48's Avatar
perki48
perki48 is offline
Received 4,181 Likes on 1,937 Posts
Expect someone to come along and tell you that will void the "engine" warranty.
I wish my 07' had a wider rim so I could run one.
  #135
Old 05-03-2018, 04:38 AM
jessultra's Avatar
jessultra
jessultra is offline
man i would have been so nervous with that wheel. can't wait to see the pics
  #136
Old 05-06-2018, 08:04 AM
PFWiz's Avatar
PFWiz
PFWiz is offline
First some pictures:
Now for the bad news,
As I mentioned earlier every time I start up the bike it throws a "Low Tire Pressure" fault (I am currently running 34 psi cold). Appearently that is causing the Security indicator ( item #13 on Figure 14 Instruments) to go on and off randomly as ride. Does anyone know if there is anything I can do other than run 40+ psi?
  #137
Old 05-06-2018, 09:29 AM
5280Ruffian's Avatar
5280Ruffian
5280Ruffian is offline
An old 4wd trick is is build a little PVC capsule and throw the sensor in it, then pressurize it to what you need. You will lose the sensor in the tire, but the fault code will stop.
  #138
Old 05-06-2018, 11:59 AM
PFWiz's Avatar
PFWiz
PFWiz is offline
Well that is an interesting idea.... seriously.
  #139
Old 05-06-2018, 02:38 PM
67Shuv's Avatar
67Shuv
67Shuv is offline
That could be easily done and stashed in a fairing pocket or taped to the inside of a saddlebag or tourpak lid. Bike looks great!!!
  #140
Old 05-27-2018, 11:06 PM
7of7's Avatar
7of7
7of7 is offline
6th Gear
I finally did it!! 25800 on my original tires.. Could have gotten some more out of the rear, but the front was used up..
Rides nice, had it up to 80, rock solid.. noted uneven pavement cracks don’t have the same violent reactions, to me it seems a little less pronounced..
Running 40psi rear and 32 in the BT-45 up front..
I used Ride-On in the back, and Dynabeads in the front..
All in all, works great!! Feels just slightly different, not an unsafe different though.
Almost ready to ride...
CHOOK (10-04-2019)
Quick Reply: Gone to the Dark Side - Ongoing Review
