Help with 107CI Woods TW-555 timing table -
4 Attachment(s)
The highlighted area shows how much timing Power Vision auto tune pulled to stop the knock. It's a pretty small area but it took a lot out.
Is this normal or does it indicate any trouble ? 2007 Road King - 107CI with Woods TW-555 Stock header with Screamin Eagle slip ons and stage 1 intake. Thank you in advance |
I don't see a lot of non false knock activity at 30 kpa at 1750-2000 rpm. I have always pretty much considered that no load, decel area. I would look into the actual data to see what is really going on.
Thanks for the response. Do I create a log and post it ? What channels would be helpful ?
It is a no load area and I'm not really hearing it. I see it on the gauges and auto tune keeps retarding it more and more. The rest of the map seems to have dialed in very nicely. |
I hesitate to use timing adjustments from PV auto-tunes for this exact reason...bad data handling creates poor results.
I believe PV needs more work... Bob |
Thanks Bob. I know the response would be to find a dyno. Would the old log tuner benefit me in any way or is there another process I could use myself ?
2 Attachment(s)
Originally Posted by Gozzie
(Post 16177108)
I would put the spark tables back to what they were before you ran the AT. Ride the bike and data log it. You can then import the data log file into to MS Excel to review it. It will look similar to the snip attached. Once you look at the data log file, you can manually remove some timing from the areas of your MAP where you see the ECM pulling timing. On the attached snip - Columns O and V show the degrees of timing being pulled by the ECM. Good luck. I still get some knock events on the PV and in the logs, although, I have never heard any detonation. I found the attached SAE document on the internet concerning non-audible knock. The technical aspects in it are above my pay grade, but perhaps you can make sense of it. |
Originally Posted by hrdtail78
(Post 16176486)
Thanks oleboy and everyone else. I feel better now reading your posts. Mine is the same as what you are saying. Barely open throttle, no load, 1750-2500 shows knock events but I cant hear it or feel it or know it's there without seeing it on the gauge. No surging and it appears to be running good.
I'm wondering if it isn't some kind of reversion going on with the cam exhaust combo that I have. I'm going to go back to the older map and play around in those areas. I don't think I can hurt anything. Maybe I'll start by raising the VE in those areas and see what the knock gauge reads. |
1 Attachment(s)
(Post 16180396)
I'm wondering if it isn't some kind of reversion going on with the cam exhaust combo that I have. I'm going to go back to the older map and play around in those areas. I don't think I can hurt anything. Maybe I'll start by raising the VE in those areas and see what the knock gauge reads. The data log will show you what is going on in those areas. See the attached snip. If the CLI is less than 100 in the closed loop, the ECM is pulling fuel. If it is greater than 100 it is adding fuel. For example in the attached snip - row 1593 shows my front CLI at .992. So my VE table value for 33.55 KPA and 3019 RPM is set at 71 in my MAP. My AFR table is set to 14.4 (.979 lambda) in this range. The ECM is pulling fuel based on what it has read at the 02 sensor in order to get the AFR back to 14.4. [VE table value of 71 X .992 equals new the new VE value of 70.5 - (columns AB and AC)]. The opposite is happening on the snip at row 1597. The ECM is adding fuel [VE table value of 69 X 1.023 equals the new VE value of 70.5 - (columns AB and AC)] in order to get the AFR back to 14.4. |
Originally Posted by FLTRI17
(Post 16176856)
I believe PV needs more work... Bob MLV kind of does the same thing, there is a knock at a point somewhere and then the way the knock control works, it takes it out gradually ...by which time you are into cells that have no knock what so dickie bird, but the "automated" programs are still averaging away quite the thing. In other words they suggest there in a level of knock when in fact, there isn't!! The settings on the config (mine anyway as an example) are set to ignore any knock below 50odd kpa so the idea of the PV saying there is knock down at 30 or 40 is maybe a bit of a stretch of the imagination. Maybe best NOT to use the auto spark tuning unless you have discussed it with Roy @ DJ first |
© 2024 MH Sub I, LLC dba Internet Brands
