The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: Vacuum Connection
Old 06-25-2017, 03:15 PM
TravisFrazier's Avatar
TravisFrazier
TravisFrazier is offline
1st Gear
Default Vacuum Connection
I have a 2004 Electric Glide Classic. It has a screaming eagle kit installed ( Not sure what that does as of yet ) I'm a newbie... Anyway there is a Vacuum Connection on the side probably a 3/8 fitting maybe a little smaller. there is no hose connected to it. The bike appears to run fine. Does anyone have the Diagram for Vacuum connections or should I just plug it so there is not dust or water sucked in ?
Old 06-26-2017, 09:13 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,256 Likes on 3,628 Posts
How about a picture?? Screaming eagle kit is a little vague as the are a number of different screaming eagle kits.
Old 06-26-2017, 09:15 AM
TravisFrazier
1st Gear
I will take pic tomorrow and post it.
Old 06-26-2017, 02:41 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Is the port on the throttle body? Yes, cap it.
Old 06-26-2017, 03:00 PM
TravisFrazier
1st Gear
Default I tried to attach pic
Not sure if attachment is attached.
Old 06-26-2017, 04:20 PM
Max Headflow
If it's the one with the cap on it in the pic then yes cap it..
Old 06-26-2017, 04:24 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,543 Likes on 3,794 Posts
I am guessing since you say SE but on most regular bodies, this is the purge line fitting for the carbon canister on CA bikes. Yes, plug, any open vacuum lines. Surprised an SE is legal in CA and would have that.
And don't plug it with the light duty cap you get at Auto Zone. Heat will soon harden it and it will fall off. Probably what happened to yours. Get the real cap at Harley.
simonantz
11-03-2015 11:52 PM
golfmajic
07-28-2011 06:59 PM
asahi1234
01-30-2011 03:59 PM
FATBOYUSA
07-14-2007 11:22 AM
Dareius
12-30-2006 12:06 AM
Quick Reply: HARLEY: Vacuum Connection
