The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: Is this an intake leak (log enclosed)
  #31
Old 09-07-2017, 01:58 AM
Gordon61's Avatar
Gordon61
Gordon61 is offline
More similar than just cams...
also
.030 HG
heads were decked for 85cc (about 8thou I think)
Street ported heads with intake ports correctly matched to a stock induction module (I was told that the stock intake ports from the factory don't quite match the induction module)
That would make the intake ports about 24thou closer to the crank, and therefore (if my maths still stands up) about 18thou less space for the induction module to fit between the intake ports.
In regard to the breather bolts; they move down with the heads so no problem there, but also 18 thou closer together ...but the size of the holes in the air filter backing plate should probably handle that.
I might have thought a compression type rubber seal would be able to cater for that kind of difference ...I've never come across another thread where anyone is trimming down the induction unit to fit ??
  #32
Old 09-07-2017, 07:17 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,031 Likes on 652 Posts
Trimming happens quite a bit. And the 124 guys go with longer manifolds for the increase in height
Gordon61 (09-07-2017)
  #33
Old 09-07-2017, 09:22 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,295 Likes on 3,652 Posts
I've trimmed a few. Even stock ones... Also had to trim intake manifolds for carbs. Depending on the amount milled and running a thinner headgasket, each side will be about 40% of head height change. Take 10 off the heads, go from a 55 to 30 thou head gasket and you might need to cut 0.012 off each side. Last head change I did was from a set of 99 heads that were cut 0.060/ 0.040 head gasket and 5 off the cylinders to a set of 06 cut 0.010, 0.030 HG and stock length cylinders. I still had to clean up the ends of the TB.. Since the bolt hole locations changed I also had to cut clearance in the TB for the screws..
  #34
Old 09-07-2017, 10:20 AM
Gordon61's Avatar
Gordon61
Gordon61 is offline
Good info. So too tight can be one possible reason for air leaks
  #35
Old 09-08-2017, 09:59 AM
Gordon61's Avatar
Gordon61
Gordon61 is offline
For what it's worth, I went at mine with isopropyl alcohol around the flanges, injectors, MAP sensor, and IAC and could not get the general un smooth idle to change at all.
Then I attacked it with a can of butane with a rubber pipe on the end so I could point it at stuff, that didn't change anything either
Mind you, I aimed the butane at the air filter for a few seconds at a time and that didn't change anything either ...maybe mine is so lumpy you couldn't see the change.
Just wondering if you do have a leak or not, looking at your logs mine is as bad as yours. Just a thought.
FLTRI17 (09-10-2017)
  #36
Old 09-08-2017, 10:26 AM
Max Headflow
At this point , it would seem to me that it's either a tuning issue or simply just the way it is...
  #37
Old 09-08-2017, 11:17 AM
Gordon61's Avatar
Gordon61
Gordon61 is offline
Yea, I'm just getting on with mine, was just in case a comparison helped Jason at all
  #38
Old 09-10-2017, 06:12 AM
misfitJason
Mine did not show a leak with butane when the intake flanges crowd the manifold. But it binded and leaked when I put it on. I had a machine shop take .040 off of the backside of the flanges and that gave me room to move them back toward the steps of the manifold to get it one. Then when sprayed it was obvious where the leak was
  #39
Old 09-12-2017, 08:33 PM
misfitJason
Haven't done **** due to a stupid hurricane. No roof damage this time. Maybe this weekend
  #40
Old 09-15-2017, 04:53 PM
misfitJason
Well I think I may have located the issue thanks to help.
The Hpi plate looked like it was centering the manifold. It was a big difference between where the oem backing plate puts it. Now, from trimming the manifold spigots, there is waay to much of a gap. I will have to find a new to me 06-up dyna manifold to start over. Anyone holding
Quick Reply: TTS: Is this an intake leak (log enclosed)
