TTS: Vtune my 2009 V-rod
Vtune my 2009 V-rod
I was trying to Vtune my 2009 V-rod stage 2, however, I couldn't upload my MT7 cal as Vtune asking for MT8 & MT9 cal to start with.
I searched for MT8 or 9 cal but couldn't find any as 2009 Vrod has MT7 only, now thinking to remove Vtune3 and upload the old Vtune version.
Appreciate any help
Appreciate any help
Appreciate any help
Appreciate any help
Thanks in advance
This is set up in the calibration. Set up the AFR Ratio table to 14.6 in the area you want to run closed loop. Set Closed Loop Bias tables to desired O2 sensor voltage that represents the AFR that you want. Under the tool tab. There is a O2 sensor voltage calc to help with this.
Thank you hardtail, its almost 10 years since last time I work on TTS, lots of changes
TroubledWine
06-29-2016 06:56 PM
60mike06FLHX
02-11-2012 08:36 PM
