GoPro accessories,,,newbie w/questions
I'm Your Guy...
First, get the Hero2, nothing less. 2nd, get the battery backpack (I have 2) and LOTS of spare batteries (I have 6). The Chesty mount is good if your bike has no fairing. Otherwise, the helmet is the most vibration-free mounting spot. ALSO: The onboard audio SUCKS, so think about an external mic. To use one, you'll want to get a "skeleton housing", the sides are open, so you can hook up your mic. It also keeps your cam cooler, they get hot in the watertight case. And LOTS of SD cards (class 10). Oh, and the skeleton housing also allows you to change the SD card without taking the cam from the housing.
For mounting on the bike, I use RAM mounts on the handlebars and on the crashbar. I gotta get to work now, but PM me with all your GoPro questions. -Steevo-
Outstanding,,thank you very much. Yeah, was gonna get the Hero2. Planned on at least a 32gb card. Six batteries? Hmmm, something makes me think that one spare just isn't cut it. Have only seen one (will research more) HD vid, but it was from a Vrod and if memory serves me correct, they don't shake like a traditional HD does. I will look into all those accessories you mentioned as well as a tether so if mount fails I don't lose the camera.
I have purchased Roxio Creator 2012 Pro and will be using that for my editing. Thank you guys so much for the help and vids.
Steevo; went to the utube channel. I'll subscribe once I get back on home computer and off the laptop. Awesome vids sir!!! Can't wait to get all my gear. Did find a homemade mount on a gopro forum i joined. Using some magnets from Harbor freight and other gear, this guy created a neat set up.
All my vids (until now) have utilized an external mic on the rear of my helmet. This is the custom mic that I made, using a GoPro quick-release camera mount.
This is how my GoPro looks on the helmet. Mounted in this spot, it's not only more aerodynamic, but I can actually see the red light blinking, so I know if it's recording or not.
Hey,
Just a few more quick things. In the above pic, this is NOT the skeleton housing. It was a stock housing with a hole drilled for the mic input. My skeleton housing was on order, but hadn't come in yet. Get one, it's worth the wait!. Also note that I marked the mic input with a red sharpie, so I won't get it confused with the tv output. Also, check out the other GoPro mounting pad down low on the front of the helmet. A cool camera angle, if your bike does not have a batwing fairing. Those stick-on quick-release mounting pads are very strong, you can put them anywhere. I have a row of them across the shelf over my workbench, for storing my spare mics and mounts.
