Rode my bike to Vacation
Hmmm, I have noticed that the front tire wobbles at higher speeds (which btw is very easy to get to quickly) what would cause this? And how can I fix it? It's a bit un nerving feeling.
I'm not saying that I did, but at 90ish, especially when leaning to say changing lanes I've noticed that the front tire seems to try and wobble and it happens quick then stops after I leave off the throttle.
One guy at the dealership said that the tires are not rated for speeds that high and that's why that happens. I also asked about tire pressure because the tubes are filled wit nitrogen. It was my understanding that nitrogen holds its pressure constantly which is why it's optimal to have. But the tech said I need to check it daily?
I dunno, what do you guys think? Have any of you experienced this?
Nice looking bike. All that rain will just make the trip more memorable.
I had a softail that had a front tire wooble at high speeds and it turned out to be the steering head bearings. The bottom one had been installed with no grease on it from the factory. Started acting up at around 10k. Loose spokes can also cause this I have heard.
Any tech is gonna tell you to check your air pressure daily, its a cover your *** thing. On a motorcycle, literally everything, is riding on those tires so checking tire pressure often is prudent. I have read that the #1 casue of tire failure is under-inflation. I bet that sporty is wound up at 90.
As for the nitrogen, it may have a place on a 200MPH indy car where 1/4# of pressure makes a big difference, but on a street vehicle it's nothing more than a gimmick IMO. It's more important to check your pressures and correct them regularly, than to put it off because nitrogen isn't handy.
BTW, regular old air is 78% nitrogen anyway.
Your wobble can be cause by, low tire pressure, loose spokes, a "cupped" tire, or neck bearings as Dave said above.
