Saddle bag lid orginizers wont stick
My saddle bag lid organizers won't stay stuck to lids... I cleaned them well and followed directions... I also tried 3m auto tape and that didn't work either. Bike is vivid black and I think the sun warms it enough that tape doesn't stay stuck to the organizers... Any ideas to fix this?
I had the same problem with the Tour Pak lid organizer. I tried better double sided tape with no success. I think the heat of the summer loosens it.
My solution was to make use of the luggage rack I had on the top of the Tour Pak. The bolts that go into the luggage rack are reasonably well spaced. I located the lid organizer on the inside of the lid and drilled thru it. I used fender washers on the bolt heads and that has worked well for me for the last 10 years. The washers and bolt heads are reasonably well hidden in the organizer.
I had the same problem with the Tour Pak lid organizer. I tried better double sided tape with no success. I think the heat of the summer loosens it. My solution was to make use of the luggage rack I had on the top of the Tour Pak. The bolts that go into the luggage rack are reasonably well spaced. I located the lid organizer on the inside of the lid and drilled thru it. I used fender washers on the bolt heads and that has worked well for me for the last 10 years. The washers and bolt heads are reasonably well hidden in the organizer.
