Upgrade to stock motor
RE: Upgrade to stock motor
57, have you checked on or done any research on the "gear drive". I would have already ordered cams, but not being knowledgeable about that sort of thing, I haven't or can't decide on the gear drive. Anyone have opinions on the gear drive?
Gary
Gary
ORIGINAL: flhtci57
I ride an 2001 Electricglide Classic; currently have screaming eagle air kit, power commander and rhnehart true dual exhaust installed. For a winter project to improve power I am considering installing Wiseco flat top 95" pistons and a set of Andrew 21G gear drive cams. I believe this conversion does it's best work at normal road speeds. It has a much wider power band than stock and can pass a truck with a mere twist of the wrist-- there's no need to downshift. Useful power starts at a lower rpm and remains far higher than stock all the way to redline, with no loss of reliability and drivability is better than stock.-any opinions or feedback?
