SE-585 vs SE-259E camshaft
Old 03-12-2015, 08:35 PM
Juice's Avatar
Juice
Juice is offline
Bump,
Anything new on the SE 585 cam?
Old 03-13-2015, 03:41 PM
slimatsea's Avatar
slimatsea
slimatsea is offline
I was at the dealer today because I wrecked my new SGS on my way to Daytona Friday and I had to order my repair estimate stuff. :-( Anyway, there was a 2013 RG there with a SE ventilator AC, V&H pro pipe chrome, and stage IV kit with the 585 cam swapped in instead of the 259E. Tuned with the SEPST it made 108 HP and 116 ftlbs. The curve looked really good. It got above 100 lbs at 2500 RPMs and never dropped back below that mark until redline.
RJ69 (06-10-2016)
Old 05-19-2015, 03:56 PM
2807's Avatar
2807
2807 is offline
Any new info on this Stage 3 with the SE585 cam and a full new exhaust and intake set up?
i am considering this asap, and sure am curious what results and info people have received.
I have a new 2015 Road Glide Special.
I anticipate the Stage 3 with the pro-tuner, VH powerduals and High Output slipping, and the HD Heavy Breather.
Pretty standard set up, I hope someone has done this already??
My fear is that the dealer and the HD parts will be limited in as far as they can go, and that go doing a local indy for the same money could get better results because he is not limited by dealer limitations.
I am in CA, but can get the full pipe system taken care of, and the dealer will tune accordingly if the bike comes in with the pipes already on.
Thanks
Old 05-19-2015, 04:41 PM
2009blackpearle's Avatar
2009blackpearle
2009blackpearle is offline
Default saw this feww weeks ago
looks similar to andrews 57 same dealer had a 57 posted 113 tq 100 hp
Old 05-19-2015, 08:51 PM
2807's Avatar
2807
2807 is offline
Originally Posted by 2009blackpearle
Screamin' Eagle 585 cams in a 2011 FLHR 103" - YouTube
Yeehaa !
Wow. But, this bike had heads too, so I will not have that.
But I decided today to do the Stage 3, SE 585 cams, pistons, and the SE Pro tuner. After asking my local indy, he said that this package, from the dealer, would be very comparable to what he would do part by part, and that getting the warranty with it on my new bike is worth it. So, I am going for it.
I'll let ya'll know how it goes. Having a lot of stuff done at the same time (paint work, stereo, trim..) so I'll be back in a few weeks with an update...
Sadly, I don't think I will have a dyno with #s for this. Dealer does not dyno. May take to indy another day for the dyno if I care to.
Thanks
Old 05-19-2015, 09:21 PM
2009blackpearle
Old 05-19-2015, 10:08 PM
2807's Avatar
2807
2807 is offline
Videos are great !
Any chance you can find one that is a new 103 with the 585 cam, stage 3, set up?
You seem to know where to find these !
Thanks for this. Great to watch, and inspiring too.
I had a 110, added a 574 Fueling Reaper Cam and VH power duals, HD Heavy Breather and dyno. I loved the power.
I am very curious to see how the 103 with a stage 3 and the same VH pipes and heavy breather intake will compare...
I will let you you all know...
Old 05-21-2015, 11:07 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
The SE585 and the Andrews 57 have very similar duration and timing numbers with the 585 having .025" more lift. the SE259 has way more duration and higher Lobe Separation ANgle. On Stock head builds all three would have similar numbers above 3000 with the 259 probably winning by small numbers. The Andrews and 585 would definitely win below 3000. Do head work and compression bump and the 259 would win that match up. Not sure why it has the .585 lift and not .555 or less for stock heads. It should be a great upgrade to the CVO 110 with larger valves and better flow.
FLYER (10-03-2016)
Old 05-22-2015, 07:50 AM
bagman1's Avatar
bagman1
bagman1 is offline
I used the S&S 585 in my stage 4 103 with heads, 50mm TB and megashots 2:1:2, it made 124/121 SAE. The guy I sold the bike to cant believe how it decimates every bike he goes up against. I still have to go up against him in my 110 to see what happens though.
Old 05-22-2015, 08:28 AM
soonerp's Avatar
soonerp
soonerp is offline
Isn't this very similar to the redshift 575 zipper cam. It comes on at 3000 rpm and peaks at 3500.
Quick Reply: SE-585 vs SE-259E camshaft
