HD Passing Lamps Fogging
Old 03-26-2015, 05:59 PM
bamatide's Avatar
bamatide
bamatide is offline
Stage I
Default HD Passing Lamps Fogging
Bought a new HD halogen passing lamp kit (#68208-98) They fog up on the inside after a few minutes. Does not make any difference if sitting still or moving. They clear up after bout 1/2 hr. or so once turned off. Any ideas as to why? Anyone else have this happen?
Old 03-26-2015, 06:08 PM
Buelligan666's Avatar
Buelligan666
Buelligan666 is offline
Maybe you got the "fog" lights. Buh dump dump.
Seriously though. Have you ridden with them where they've been on for an extended time. Sometimes the moisture will evaporate out after the lamps have been run for awhile. I've had moisture trapped in cheap aftermarket headlamps for a truck I previously owned. I put a couple of those little silica "do not eat" bags in there and got the bulk of the moisture out.
Old 03-26-2015, 06:44 PM
oc1014's Avatar
oc1014
oc1014 is offline
Welcome to the forum. Wash them out with isopropyl alcohol and and rinse with water. It's a common problem. I also use an air chuck to blow out any water after washing.
Old 03-26-2015, 06:51 PM
tecnomec's Avatar
tecnomec
tecnomec is offline
6th Gear
i agree put the bags behind the light in the housing should do the trick
Old 03-26-2015, 08:54 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
GriffinDenim13FLHX is offline
Clean well inside with alcohol then add some LED bulbs in side problem solved. (If they are the kind that you can replace the bulb)
Ultra 99
Electrical/Lighting/Alarm
02-14-2019 12:37 PM
eagle56
09-02-2012 03:44 AM
Elginator
11-01-2007 05:48 PM
russl179
10-10-2007 05:42 PM
drumer66
07-17-2007 05:59 AM
Quick Reply: HD Passing Lamps Fogging
