MPG Open trailers VS enclosed V nose
#31
I've towed up to three bikes on an open 7x14 single axle cross county without issue. It has an expanded metal ramp but if I'm only towing one or two I can lay it down on the trailer deck and it pulls like it's not even behind me. I pull it with my 02 Tahoe or my wife's 13 Yukon Denali. For my next trailer I'd like a little longer and two axles. The single has done fine for me over lots of miles despite what everyone here thinks of them.
#32
#33
Since I already own a Wells Cargo 6x10 v-nose, that is what I use. Yeah I take an MPG hit, but I really do like the security and weather protection it gives (for whatever I’m hauling). I put electric brakes on it which was a nice upgrade, and my V6 Tacoma handles it fine.
Those enclosed Iron Horse units do look good tho!
#34
you really want:
2 axles
brakes
I have seen more single axle trailers rolled at the side of the road than I can count.
the most recent and spectacular was an open trailer with a single axle, no brakes.
2 roadkings strapped in, side by each
the right tire tire blew, the trailer dropped down on the right side and started pulling.
the driver braked hard
the trailer has no brakes and tried to pass the suv on the right.
it jerked and one of the roadkings went over the side...it;s straps pulling the other road king and the trailer on top.
mpg should be the least of your concerns, check the rating of you van- what can it pull, how much tongue weight
an open trailer will have alot of drag and may offer more resistance than an enclosed trailer - a V front will do better, but see if that is wasted space
mike
2 axles
brakes
mike
#35
you really want:
2 axles
brakes
mike
2 axles
brakes
mike
I have both. The closed trailer allows much better fuel mileage than the open. I have pulled both at hiway speeds. The overall difference in mpg is around four mpg. Protection from the elements and security should also be considered. Hope this helps.
#36
#37
Unless I couldn’t afford it I would absolutely always and only buy an enclosed trailer for bike hauling of any distance. Sure, you can do it on many lesser trailers and have no problem. I just prefer the protection and security offered by having the bike inside. I also use the cargo trailer to haul any additional gear (often in totes) going on the trip. V nose trailers with dual axles and brakes are what I prefer.
#39
I lost a 6 x 12 single axle on the highway in slippery conditions once. I was passing a semi when the draft off the front of the semi hit the trailer and sent it swaying wildly and ultimately sent me into the median with it on it's side and yes I had over 200# on the tongue. Not that I wouldn't haul a single again I would just be more mindful of my surroundings and conditions. I have towed various pieces of farm equipment and boats all my life so I am not a newbie at it.
If I had to buy I would either go light and open like an Aluma Lite with a rock guard for protection or dual axle enclosed depending on what I was going to do with it. I tow so infrequently I just rent U-Hauls for when I have to.
#40
