RideStra8 or TrueTrac comments, please
I'm trying to correct a high speed wobble (65-70mph) on my SG that usually occurs when I'm hit with a cross wind. E.G. if on a bridge with a cross wind the bike will wobble across the whole length. Scares the crap out of me!
My question; do any forum members have either of these stabilizers instaleed on their rides and if so did they make a difference? Would like to know before I spend $440.
The bike has been to the dealer andevery thing that may cause a wobble has been checked out and of course "no trouble found" lol!
I've called Harley customer service 2x waited 20 minutes each time, never got answered, hung up. What a wasteof time.
Opinions please. Thank,
Frank
Frank
RE: RideStra8 or TrueTrac comments, please
I occasionally experience what I'll say are the same same symptoms on my RK.
Mine is definately a 'front-end' thing. The way I would describe it it that sometimes when I'm bucking a headwind, (always going into the wind) a gust sets off some sort of harmonic ocillation in the steering. It's usually easy to get it to stop, but it catches me off guard sometimes.
This is NOT the rear of the bike in my situation. ie, not rear wheel steering. Having True-Track or otherwise isn't the cure this one..... at least on my RK.
CN
CN
I just recieved my Alloy Art stabilizer (it's new onthe market). I'm installing it and giving it a test ride this weekend, I'll let you know. BTW mine was only $319 less shipping and handling from M&M cycles.
I have a post on this forum, added a day or so agao.
Glenn
Glenn
I had the same delema as to what I wanted to improve the handling on my Ultra as well...
Prior to adding the ride sta8 I was tossing the true track around and after doing some reading on the 2 systems I desided on the ride str8...Note: I never noticed the shimmy that others have experienced on my ultra, however I did notice it on my fatboy and turned out to be the neck bearing needed to be tightened...Tightening did help but wasn't the cure all...
After the installation which by the way was asimple proccess to say the least I notice a improvement right away...The *** end didn't have the wag anymore while riding aggressively...
I had read about the sta-bo's and decided after a couple months or so to give them a try and what a night and day improvement...The bike just felt so solid that it was like riding a sport bike...
I would suggest that you might try the sta-bo's first and if that doesn't solve the problem then decide on which stabolizer system you want to go with and install it...
I have a custom shop down here and I hang out there from time to time and one of the firemen had the alloyart system put on his ride and after a short time he had it removed...He was complaining about the additional vibrations that he was experiencing...hes considering one of the other systems that his fire buddys are running over the other...Shop is suggesting the sta-bo's first and see what he thinks and then go from there...Food for thought...
ORIGINAL: TexasBowhunter
https://www.hdforums.com/m_1559707/m...tm.htm#1637757
get with Mike,he can set you up
