Heat shield for right side
All,
I'm looking for a heat shield to cover up the right side exhaust pipe from just past the bend all the way back to the muffler in one piece. I'm have eliminated the stock cross-over pipe and used a dual conversion kit. The kit re-uses the 2 stock heat shields by flipping their positions. I was looking to clean this area up with a one-piece shield. Any ideas where to get one or have it made?
I appreciate any feedback....
Just used a hack saw. It doesnt have to be real pretty, it will be covered up. When you set your rear piece of heat shield in place you will see how much you need to cut off the center piece. The only reason you even have to cut some of it off is because the clamp for the new 12" section is back far enough that it wont overlap enough.
The closest pic I have is the one in this post
https://www.hdforums.com/m_1638697/m...tm.htm#1638697
