Road Glide fairing thrust angle?
While riding straight down the highway my 16 RGs fairing seems a little pointed to the left and sort of twisted. Not certain why. Sort of like driving behind an out-of-alignment car that you see "crabbing" down the road. Am I imagining this? Is there index marks to make sure the fairing is pointed straight ahead? Is the fairing fully factory installed or is it partially set up as it comes out of the crate.
Sort or weird. Like to know if this is common and a problem or in my head. Bike has NEVER taken a "nap". |
My 15 Road Glide CVO points a little to the right. Also wondering now. Thought it was just my crooked Head
My 15 RG CVO points left. The dealer has tried to fix it 3 times and failed so I decided to have a look myself. The fairing is bolted to a plate which is welded to the frame and I figure the plate was welded on crooked at the factory. The only way to fix it is to shim the fairing on one side. Very poor quality control IMO.
Thanks for your feedback.
Hmmm, interesting. Guess I'll get use to it. Crap. |
I'm SO F'ING glad to hear this. I had my 2011 RGU for 4.5 years and I always thought the same thing but no one believed me. Every mechanic I asked to look at it swore they couldn't see what I was talking about.
There are other threads on this. This is a fairly common problem on Street Glides also. QC issue? Sure. Just many things churned out by the MoCo. I made my problem worse when I installed the HD speaker trims. They showed me how far off it is. I have adjusted mine twice and it still isn't right. I think only the anal retentive people notice or care enough to try and fix it..... I guess I am that way sometimes.
A while back a friend complained of the same thing. We measured from the back of each side of the fairing to the seat screw and there was almost a one inch difference...
Could the headlights be turned a little bit to make it less noticeable?
You cant always expect perfection when bikes are mass produced and there are literally thousands of bikes just like YOURS.
Not sure if you can really do anything about it. Complaining might help but the result will be the same |
Originally Posted by DanHappy
(Post 15321599)
Accepting this just because the bike is massed produced is pure crap. It's poor construction technique and poor quality control plain and simple. There is no excuse. |
© 2024 MH Sub I, LLC dba Internet Brands
