Largest rear tire 02 RKC
Old 08-05-2016, 07:13 AM
Goose_NC's Avatar
Goose_NC
Goose_NC is offline
Received 4,280 Likes on 2,004 Posts
Originally Posted by FrankCaputo
Nope, can't hurt though can it?
Only if you exceed minimum clearance for the belt. Not only does it move when the bike is rolled backwards. It moves when decelerating also.
Also, a 140 from one manufacturer may be wider of slimmer than another. By as much as 10MM.
Livingmydream (08-11-2016)
Old 08-05-2016, 07:25 AM
twistedcherokee's Avatar
twistedcherokee
twistedcherokee is offline
Some can & some can't. I have run several 140's from different manufactures and ran into one that rubbed. But it rubbed on one of the inside fender bolts. https://www.hdforums.com/forum/touri...tire-rubs.html
Toby
Old 08-05-2016, 11:08 AM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
Originally Posted by just plain john
What about the Metzler 888?
Some of the Brazil made 888's have tread separation problems.
Old 08-06-2016, 08:52 AM
Livingmydream's Avatar
Livingmydream
Livingmydream is offline
So the metzeler 888 mu85 would fit without trimming the belt guard or a spacer?
Old 08-06-2016, 09:18 AM
xcbullet's Avatar
xcbullet
xcbullet is offline
You don't trim , it's removal of the rubber flap by drilling out three rivets. The flap is for stones so if you do dirt roads u might not want to remove if not you won't miss it.
Old 08-06-2016, 09:26 AM
bagman1's Avatar
bagman1
bagman1 is offline
Originally Posted by GooseGRMC
So, you are planning on exceeding 783 pounds on the rear tire? If you just said 'I like the wider tire looks' I would have left you alone.
How much weight you think is placed on a rear tire on a loaded touring bike, with 2 people with a combined weight of say 425 lbs? I think you would be surprised even shocked. Swore I was going to do an axle weigh, but never got around to it.
Old 08-06-2016, 09:30 AM
nb472's Avatar
nb472
nb472 is offline
On my 02 rkc a 140 would have not fit,too close to the belt. I ran Metzlers 888 for over 40,000 miles without a problem. I would get around 10,000 miles out of them,but I am very **** about tires.
Old 08-06-2016, 02:31 PM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
Can't find any specs on the tire width. I have the 880 mu85 on mine, I did trim the flap on the guard. Took all of 10 minutes and has 1/8"-3/16" belt clearance.
Old 08-22-2016, 07:18 AM
Livingmydream
So I went with a Dunlop 402 mu85. Hopefully it'll fit. I'll let you all know the outcome
FrankCaputo
06-01-2016 11:25 AM
Slow-Joe
01-21-2015 08:41 AM
scorchedearthpolicy
Wheels/Tires
04-03-2013 02:58 PM
cowpoke
04-26-2012 09:22 PM
nardo
11-22-2007 11:42 AM
Quick Reply: Largest rear tire 02 RKC
