Road King Rear Light Bar Swap
I am really wanting to get away from the ultra wide rear signal bar on my 12 FLHR and go with something a little more compact and tidy. I am currently looking at the bullet signal bar that the Moco sells.
http://www.harley-davidson.com/store...signal-bar-kit
They state that it fits the Classic King, but not the standard King and I am assuming that this is because the classic does not have the tag light underneath the bar. Is there a way that this item would fit with the original plate light and plate mount? Has anyone done anything like this or do you have any other options (besides an entire SG rear fender) that would clean the back end up some.
Thanks guys
Thanks guys
That's cool. Here's what we did with our Road King. I love it! These things are very cool. Got them from our friends at Black Hills Billet. They are called ArrowLites. These work as both brake and turn lights. The smoked LED tail light is theirs too. Top quality. Made in USA.
BlackHillsBillet.com
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
General Inquiries:
Phone:
775.331.3789
That really looks good. I was considering running some CD gap filler lights in the gaps but I run into the same issue. I would have to MAKE it work instead of a company just making a product that cleans the back end up. I have a curved tag mount but I'm not sure that I could stand the bolts and mount holes protruding.
Thanks guys
Thanks guys
Good question, that part I'm not sure. I thought the frames were all changed in 09 and therefore the fender. Probably should check Ronnies online microfiche to make sure.
OP -
I looked into this swap awhile ago. I was trying to determine which part number would work for my '14 RK
I believe I got this info from forum member 'Cathead', for the part no. for a SG/RG-style rear bullet turn signal that would fit my '14 RK:
Rear Bullet Turn Signal # 68997-09. I believe Cathead indicated he used the tag light from the stock RK signal bar because it didn’t require splicing...he found it easier to remove the tag light from the original "2x4" turn signal bar and swap it out with the one that came with the 68997-09 kit.
Cathead...can you confirm??
Check out the above info carefully...I haven't done the conversion yet. Let us know how it works.
OP -
Here's another more cost-effective option I am considering for adding front and back 'bullet' turn signal bodies to the stock front/rear light bars on my '14 RK:
Bullet Turn Signal Body Kit (front/back) – smoked lens and amber bulb – HD Part No 69153-03A - http://www.adventureharley.com/harle...ulb-69153-03a/ This kit also comes with an amber lens (different part no.) if you prefer. I am considering this kit option because I could not find front-only 'bullet' turn signal bodies that would fit the stock front light bar on my RK.
There is also a kit that has 1.5" shorter rear turn signal bar extensions for the RK (see HD accessory manual). These extensions are styled the same as the stock rear turn signal bars, only shorter in length...and they should work with the above front/rear bullet turn signal kit (69153-03A).
OP -
