More Compensator Blues
Old 02-16-2017, 05:00 PM
PeterV's Avatar
PeterV
PeterV is offline
Not a big deal, and easy, since you don't have the stock exhaust (I'm assuming by the pic).
Comp nut will go loose sometimes, mine waited til 140,000 miles before it complained, right after I had a go with a 370Z
New nut is 40392-91, loctite it, torque it, you're good to go another 70+k
Old 02-16-2017, 05:43 PM
Pothole914's Avatar
Pothole914
Pothole914 is offline
Received 3,682 Likes on 1,469 Posts
So, you just replaced the nut and that eliminated the racket on hot start ups??
Old 02-16-2017, 08:45 PM
PeterV's Avatar
PeterV
PeterV is offline
The racket is caused by by the nut (25) coming loose and the cover assembly (24) making contact with the cams (ramps)(23).
I just wanna get something clear. Is this noise only present during hot startups or, is it intermittent as you ride?
Old 02-17-2017, 05:32 AM
Pothole914's Avatar
Pothole914
Only happens during hot start ups. Never heard it while riding.
Old 02-17-2017, 06:08 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,413 Likes on 3,311 Posts
If you're gonna open it up, change the comp ....
Old 02-17-2017, 06:12 AM
PeterV's Avatar
PeterV
PeterV is offline
Then, it's not your comp.
Sounds like jackshaft smacking on the ring gear.
Old 02-17-2017, 06:19 AM
Notgrownup's Avatar
Notgrownup
Mine only acted up at hot startups and it was the Comp. both times, as a matter of fact, the first time it happened they put a high torque starter in the bike to no avail.
Old 02-17-2017, 08:40 AM
Pothole914's Avatar
Pothole914
I kinda thought that but, when I opened it up to change the starter clutch, there were no marks on the ring gear or the jack shaft that would indicate "smacking" or grinding.
Old 02-17-2017, 02:24 PM
PeterV's Avatar
PeterV
PeterV is offline
Well, I've had the solenoid go on the starter, had the jackshaft slam on the ring gear, that sure makes an awful noise, and had the comp nut come loose on both rides and that sure makes a constant racket.... hope you get it figured out and post the results. Good luck
Old 02-17-2017, 03:07 PM
Notgrownup's Avatar
Notgrownup
I think what was explained to me was that if the comp is a bit weak that it is like it throws the harmony of the starter engagement or something like that... Hell , I don't know, it could be a faulty flux capacitor..
Quick Reply: More Compensator Blues
