Need Help, 02 Ultra front wheel swap
09-27-2017, 01:24 PM
I have a 02 Ultra classic, Looking at swapping the front wheel to a 17in 09 street glide. Has anyone done this or know if ill have a problem ?
thanks
09-27-2017, 01:42 PM
You would need to change the bearings in the new wheel to the 1 inch that the 02 uses for starters. The brake rotors would be the other issue. Unless you have upgraded to the 11.8" and Brembo brakes of the 08 and up, the rotors on the new wheel will not fit. Depending on the mounting of the rotors you may be able to swap your 02 rotors to the 09 wheels.
Neil
RDMC
09-27-2017, 02:09 PM
09-27-2017, 02:11 PM
Looks like the rotors may swap out.
09-27-2017, 02:16 PM
Yes, the rotors will swap. Using the 1" bearings will require outer spacers .780" wide.
09-27-2017, 02:20 PM
Did the sg come with 17" wheels on front?
Will my spacers not work?
09-27-2017, 02:23 PM
that's what the guy says that has it
09-27-2017, 03:20 PM
Just checked online parts site and the stock front wheel is only 17".
Neil
RDMC
09-27-2017, 03:26 PM
Mine is an 02. Which is 16in an the 09 is 17in
