light bulb under bike during winter storage
Old 11-09-2017, 11:13 PM
svarnster's Avatar
svarnster
svarnster is offline
I couldn't resist . I ride year round here I rarely see a thermometer reading below 30. But I insulated the attic in the garage and I never get condensation on the bikes. I had a 12 x 12 work shop before and it would look like it rained inside from all of the condensation.
Old 11-09-2017, 11:32 PM
DAVENRINO's Avatar
DAVENRINO
DAVENRINO is offline
What is this winter you speak of?
Old 11-09-2017, 11:38 PM
groupw's Avatar
groupw
groupw is offline
Originally Posted by giacomo56
.... and don't forget the Music CD of the ocean waves........
..... i highly recommend 'The Psychologically Ultimate Sea Shore' ..... some badass breakers on that one
... when it got below zero, i used to put a trouble light under the hood of my Ford which sat out overnite when I was in high school, but never w/the Road Glide
........ of course, the Road Glide doesn't sit outside either.
Old 11-10-2017, 01:16 AM
bklynbob's Avatar
bklynbob
bklynbob is offline
Oy....
Old 11-10-2017, 02:39 AM
Ride my Seesaw's Avatar
Ride my Seesaw
Ride my Seesaw is offline
Received 1,570 Likes on 736 Posts
Cover the open end of your exhaust pipes with plastic bags and a rubber band to keep the moisture from getting into your engine's internals. Your valves could be open depending on where your engine stopped.
Old 11-10-2017, 02:54 AM
H20loo's Avatar
H20loo
H20loo is offline
I run a fan 24/7 when the frost is coming out of the ground (cement) and thru the rainy month of April. Not just for my bike but my tools and equipment.
Old 11-10-2017, 04:52 AM
r1cochet's Avatar
r1cochet
r1cochet is offline
The heat may attract rodents that will build a nest somewhere on your bike and chew on the wires and other parts...
Old 11-10-2017, 05:03 AM
Just Mike's Avatar
Just Mike
Just Mike is offline
Received 3,158 Likes on 997 Posts
this is what I do. Cover is laid loosely on bike, only to axle nuts, then fan blows under cover, and around garage.
The constant air movement keeps condensation down, doesn’t create heat to attract unwanted house guests and only costs a few bucks to run all winter long
my bike doesn’t sit for too long unless we get a really bad winter.
Old 11-10-2017, 05:17 AM
overthehill?'s Avatar
overthehill?
overthehill? is offline
Good advice....one other thought - instead of the chore of getting tires off the ground, just pump them up to around 50 lbs. In the spring it avoids the flat spot....of course deflate to advised pressure before riding again.
Old 11-10-2017, 11:29 AM
xcbullet's Avatar
xcbullet
xcbullet is online now
Had mine in a shed last couple years, would get condensation. Tried a couple of things. This year going to leave in garage if it gets condensation I'll fire it up and go for a ride. Yes it does matter, they corrode, even under the chrome. I have mine nice now and want to keep it that way. Thought about using climate control storage unit but for the price I can just leave the insurance on and ride it from time to time when the roads are clear.
Quick Reply: light bulb under bike during winter storage
