09 Road King engine swap
Hey guys,
A buddy of mine just upgraded his trike to a 120 from a 103. After building his engine up, he didnt think it was fast enough so he decided he'll just go up to 120 and build that up. So he now has a built 103 in his garage. That engine was fast! I remember not being able to keep up with him when we both take off at the same time. And mind you that is a fully loaded trike!
Enough with the back story. I was fortunate enough to get that motor from him for a whopping $0.. (Nice to have generous friends!) Anyways, come fall/winter months, i would be doing the swap myself. Only because i want to learn how to do it and partially too cheap to spend 2k for the dealer to do the swap.
Would I need any special tools on doing this project? I know HD loves to throw parts in their product using weird tools. Ive been doing research and i cant seem to find anything about special tools needed. I just want to confirm that from you guys.
Any input would be greatly appreciated!
Thanks!
Thanks!
The service manual is invaluable as it will detail the sequence of removal and installation to include all of the important torques, etc. You will not only need tools to remove the motor / primary / drive system but also the gaskets and seals for reassembly. Furthermore, as you are going from a stock 96"? to a performance 103" you will need to upload a new map to the ECM. What about intake and exhaust for this high performance 103"? Are you running a stock exhaust on your current motor?
So, not only do you need the tools, manuals, gasket kits, you potentially need other supporting parts to complete the swap? You may find that by the time you cost all of this out it may be less expensive to upgrade your current motor?
Last but not least, I don't know about Washington, but here in California the engine is part of the bikes title. What are the rules in Washington for replacing motors?
Received 17,621 Likes
Hey guys,
Thanks!
Thanks!
I have changed a motorcycle engine in California. You need a bill of sale or anything showing it’s origin. Then DMV will send you to the highway patrol to check the engine vin to make sure it isn’t stolen and then you will receive an amended title showing the updated engine vin. It’s just paperwork
Hes a very good friend of mine. Id say the $0 price tag will even out most of the stuff we've done together.
Thank you! I will look into that. I dont mind buyimg the tools. I just need to know what I need to get. Im sure we have most of the mechanic tools needed, just the special ones im worried about.
I also got all the gaskets needed for the swap. We are actually doing this swap in a mechanic shop (car repair) so most of the basic tools needed will be available. Im just not sure of any special tools.
In regards to engine swap in Washington, thats a very good question. I dont know of any rules about changing them. Maybe i should look into that as well. When my buddy got his swapped, he didnt mention anything about contacting DMV. hopefully its just a california law.
