Pulling power?
I have a 2012 FLHTK and pull a trailer. I have the 255 cams with a factory download. S&S Stealth air cleaner, decatted header with V&H fishtail slip ons. I also utilize a Rekluse clutch. I have plenty of power to pull the trailer. I live in Idaho so it gets used in the mountains. Good luck with your decision.
the differences are somewhere other than the gearing. if you go to the harley service information portal, you can pull up the owners manuals for virtually any bike. i compared the gearing on my old 2010 96'' to my wife's 2012 103'' and the gearing was exactly the same. same number of teeth and sprocket, and same overall gear ratio
Your probably right, I keep thinking about the 2010 I had. There was something wrong with that bike. I bought it new and came off a goldwing,and thought that was just the way the HD's were. This 2012 is much better. I now have a leesure lite camper that I pull. (Still have goldwing trike) Now this sounds like a lot,but it really is not. I had it weighed ready to camp, less food, and it weighed 480 lbs. It pulled behind the wing like is was not back there. I thought the scales must be wrong so took it to another scale 20 mins later and was 480 lbs. it's easy to have more back there than one might think.
Stock 103 with slip ons and an FP3 pulls just fine. The only time I noticed it being sluggish is at high altitudes going up mountains in Colorado, but my wife’s 96” did the same thing not pulling a trailer.
You will be fine with out modifications, but your fuel mileage will suffer when pulling.
07/08 have higher gears due to the rear pulley. 06 in 5th is the same as 09+ in 6th. Harley obviously realized their mistake and changed the gearing back. That's why 07/08's are slower out of the hole and typically don't use 6th until 75+ mph. Not to mention the 96 vs the 103. It's why I just picked up a Japanese sportster pulley for my 07.
